Moser 9" whine
Old Jul 22, 2006 | 11:20 PM
1fast97gsx's Avatar
Moser 9" whine
My car has a moser 9" with a 3.90 gear and a detroit trutrac installed all assembled by moser. The car runs great, but only under slight throttle I will get a whining noise from the rear end. I'm not sure how to describe the loudness of it, but it's definitly noticeable inside the cabin. With the radio at a moderate level you can't hear it. If I'm going say 40 mph and completely let off the gas and just let the car coast there is no noise whatsoever, if I just push the pedal far enough to keep the car at a constant speed or slightly accelerate I will hear the whine. If I push the gas down a little more the whining appears to stop or at least quiet down. ( I can't tell because of the exhaust noise )
A few friends have seen and heard and it a few said it's normal with a 9" and that gear, others said it shouldn't make any noise, some said don't worry about it, others said fix it. I checked the fluid level and it's fine and fairly clean. I'm looking for opinions on whether this is normal or not and if it's something I should worry about? If I have the cutout open ( basically just before the rear end ) I can't hear the whine, with it closed I can hear it. Opinions / advise?
Old Jul 22, 2006 | 11:32 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I have heard that some gears make more noise than others. What brand of gears do you have?
Old Jul 24, 2006 | 03:46 AM
1fast97gsx's Avatar
Not sure on gear brand. The rear end was already in the car when I bought it. The reciept just says bolt in moser 9" rear end with 3.90 gear and detriot trutrac and it was $2599 I think.
Old Jul 24, 2006 | 11:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
the Moser 9"'s are known to whine a bit after you get on it a few times.
Old Jul 25, 2006 | 02:26 PM
1fast97gsx's Avatar
That's what I figured as well, just wanted to get other peoples opinions. I guess I just won't worry about it.
Old Jul 26, 2006 | 08:48 AM
bygblok's Avatar
I could hear the whine in my 9" until I went to the true duals and spin tecs. It seemed better after I drove it a few miles though. Might be just the break in period on the gears but if it's not real bad I wouldn't worry. Unless you've got some real HP you're not gonna break the gear!!
darwinprice
17
Oct 11, 2015 11:51 PM
thejimsterz28
Sep 30, 2015 08:52 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Youngs92
Sep 23, 2015 11:29 AM
