$25 for a 4th gen rear? worth it?
Old Jul 25, 2006 | 12:01 AM
SMKNTRS's Avatar
Seems really cheap compared to what i seen what some of you guys paid on here. It has 3.23 POSI w/ Disc Brakes (a given).. needs a pinion bearing, calipers, rotors, pads, hoses and assuming e-brake stuff. 64K.. lemme know what you guys think
Old Jul 25, 2006 | 12:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
very cheap. i'd guess it's pooched.
Old Jul 25, 2006 | 08:41 AM
Needs a pinion bearing = needs a gear setup
So here's the "decision matrix":
What does a non-destroyed one of those cost? Most people have been paying $250-300 or so for a COMPLETE one, rotor to rotor.
What does a "gear install kit", plus labor to do a gear setup, cost? Kit is $100ish, setup labor is about 2-3 hours at $75/hr, or $200-250ish. Total cost, $300-350. And that's assuming of course, that nothing else is destroyed; such as, the gears, or the carrier. Add to that whatever is missing: rotors, calipers, pads, lines, etc.
Doesn't sound like a deal to me. Wouldn't be, even if it was TOTALLY FREE.
Which is why it's all but totally free. It's worthless. In fact, its value is less than zero; it has negative value. It's a liability to whoever has it, not an asset.
Old Jul 25, 2006 | 04:59 PM
SMKNTRS's Avatar
i'm not real familair with rear ends but the part itself from napa is 27 dollars or so and he said the rearend works as it is but it whines a little so he suggest changing the bearing out.
Old Jul 25, 2006 | 05:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea, guy who wants to dump the rear on you said it's only the $25 part... Once you realize that the whine is not only caused by the failed bearing, but what the gearset did to itself as the bearing was destroying itself (the gears are MUNCHED), then sofa's comment makes more sense.
It's *highly probable* that a new bearing won't fix that gear howl.
Old Jul 25, 2006 | 05:44 PM
SMKNTRS's Avatar
http://http://cgi.ebay.com/ebaymotor...QQcmdZViewItem
Old Jul 26, 2006 | 08:45 AM
SMKNTRS's Avatar
anyone look at the auction? i told the guys what you said and he got snappy with me and said not to bid on it, haha
Old Jul 26, 2006 | 08:53 AM
Yeah I looked.
He's looking for "the greater fool". You've already established that you're not the fool he's looking for. So he's done with you.
Think about it.... it whines so bad ("a little" .... my a**) he changed it out. It's bad enough that he ALREADY SPENT MONEY to get it out of his car. Which means, he already KNOWS PERFECTLY WELL, it costs less to get another one, than it does to fix that one, because if it was economical to repair this one, he'd have repaired it himself, right? Now he knows that you've also figured it out.
Buying used cars and car parts is like this. Even people who aren't "dishonest", can't be trusted. But there are 2 rules you can take to the bank:
1. You get NO MORE THAN what you pay for; and
2. If it sounds like it's too good to be true, then it IS too good to be true, meaning, it's not true.
Seems like, this whole deal fails the test, all the way around.
Keep looking, there's plenty of them out there. Last time I was in my local junkyard, I saw 2 sitting there; $250 apiece. They're everywhere. People are wrecking LS1 cars at an amazing rate, so for the time being, they're plentiful.
Old Jul 26, 2006 | 09:29 AM
SMKNTRS's Avatar
Yeah I looked.
thanks the comment about "the greater fool" was a good way to describe it. I think if he was 100% honest that he'd try to convice me why it wasn't junk with some fact. I'll keep an eye out, thanks. Without you guys I woulda hopped on this thing and been in a tight spot. thanks again
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
