Will Dextron IV mix well w/Dextron III???
Old Jul 29, 2006 | 01:59 AM
92GTA's Avatar
I just bought a 12qt case of ATF from my GM dealership and they gave me Dextron IV for my specific car. It's says on the bottle it's for use in Dextron II & III transmissions.
However I am installing a new TQ converter and I have a 24K GVW fluid cooler. Due to the additional cooler, I expect there will still be Dextron III in my system.
Will I run into ANY problems using the Dextron IV and the 2 mixing?
Thanks!
Old Jul 29, 2006 | 03:46 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I believe Dexron IV is backward compatible with Dexron III.
Old Jul 29, 2006 | 05:40 AM
Bowtye101's Avatar
Car: 1991 RS/ 2006 Charger R/T SRT-8
Engine: 383 4bbl / 6.1 liter HEMI
Transmission: TCI 700R4
Axle/Gears: 3.42 posi
Dex IV
Dextron IV is just an advanced formula just like III was to II so to answer your question YES for any fluid info just go to vavloline's web site and wal la you'll get all the fluid info you will ever want.
Old Jul 29, 2006 | 07:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All newer fluids are backward compatable and there's no T in Dexron.
You can mix oil also. You can mix 10w30 with 20w50 if you want but you won't get a consistant multigrade.
MrPackstin
Oct 25, 2017 08:09 PM
92-Formula
Dec 12, 2015 10:34 PM
HoosierinWA
Oct 7, 2015 10:15 AM
rusty vango
Sep 29, 2015 02:44 PM
TheExaminer
Sep 28, 2015 02:28 PM
