speedo gear
Old Aug 2, 2006 | 05:18 PM
16KS's Avatar
Car: '91 Firebird Formula
Engine: 350 (carbureted)
Transmission: Th 700-R4
Axle/Gears: 4.10
speedo gear
my speedo is off from my 4.10, i know how to change it but where is the best place to get the new gear that i need
Old Aug 2, 2006 | 05:29 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Not sure if its the best, but i bought all 3 of mine from ck performance (718 784 4256) Just call up tell them what tranmission and gear ratio you have and they figure it out and send you the new speedo gear. I think it came out to about $45 for the gear, housing, and shipping. Not sure if thats cheap or expensive but they have good service and I have no complaints
Old Aug 2, 2006 | 07:15 PM
16KS's Avatar
Axle/Gears: 4.10
ok cool, thanks i appreciate it
Old Aug 2, 2006 | 07:30 PM
Pro Built Automatics's Avatar
The lowest ratio GM or anybody else makes is a 15 tooth drive, and a 45 tooth driven. The housing must say 40-45 on it to use a 45 tooth driven. If your tire size is 27.5" in diameter, and you are running a 4.10 gear, and use the 15-45 gear setup, then this is the lowest the factory setup will allow. If your tire diameter is less, then you will need to go to a speedometer specialist to make an adapter to have the speedometer read correctly. They can charge $100.00-$200.00 for this.
Old Aug 2, 2006 | 07:39 PM
16KS's Avatar
Axle/Gears: 4.10
oh, well ill have to look at it all then and see what my situation is, thanks
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
