Loud Bang from rear 1-2 shift
Old Aug 4, 2006 | 04:52 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
My car has been out of commission for the last month or so. Just got it on the road last weekend, sure beats the 4 banger Sunfire beater I have been driving.. Anyway.
Tonight on my way home from work, there is a spot I have to do a U turn on a busy road. Got some room, and floored it. As the car shifter from fist to second, the car used to make the tires bark, well tonight instead I heard a loud metal to metal bang noise... My tranny does have a stage 2 shift kit.. So I'm wondering if I broke the rear gears, or something?
Anyone with any thoughts on the matter?? Thanks
Old Aug 4, 2006 | 05:12 PM
JDud's Avatar
Were you able to drive it home? Does is still shift up through the gears? What else can you tell us about how it behaved after the "thump"?
Old Aug 4, 2006 | 07:06 PM
scanman717's Avatar
Engine: LB9
If I keep my foot out of it, IE drive it "normal" it is fine. If I floor it from a dead stop it makes that bang noise and "feels" like its slipping for just that moment, then it seems fine, until it shifts, then it does that again...
I just went out for dinner and a test drive. It seems that the noise and the "bump" I feel when this happens is only on the passenger rear. Could it be the axle slipping???
Old Aug 4, 2006 | 07:13 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Check the transmission mount first. They often break.
Old Aug 4, 2006 | 07:36 PM
scanman717's Avatar
Engine: LB9
It does look like it has seen better days. I will replace it tomorrow morning and report back..
Old Aug 6, 2006 | 10:18 AM
scanman717's Avatar
Engine: LB9
Yep, Busted Tranny mount. New one is in and all is well.. Thanks!!!
Old Aug 6, 2006 | 12:29 PM
James Montigny's Avatar
http://i38.photobucket.com/albums/e1...n/PICT4461.jpg
It happens
Old Aug 6, 2006 | 02:54 PM
scanman717's Avatar
Engine: LB9
Yep. That's exactly what it looked like..
Old Aug 6, 2006 | 03:52 PM
Did you replace it with rubber or polyurathane?
Old Aug 6, 2006 | 05:09 PM
scanman717's Avatar
Engine: LB9
Replaced with just rubber..
Old Sep 2, 2006 | 04:30 AM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
i put a new rubber mount just about every year. it's a PITA! my car is on it's third transmision. oh well... forgot how many mounts i killed.
Old Sep 4, 2006 | 10:17 AM
Pat Hall's Avatar
Tsk, tsk, tsk! You coulda bought a poly mount by now with all the money you've spent on the worthless rubber ones! I managed to break the rubber ones with my anemic 305 TBI. Put a poly one in and haven't had a single problem since. Definitely a good upgrade!
Old Sep 4, 2006 | 10:55 AM
After replacing my rubber one with a poly one, and not liking the vibration, I went back to a rubber one. I broke it within 500 miles (WOT tuning)
I replaced it with a tougher LS1-style mount. Let's see how long this one
lasts.
Old Sep 5, 2006 | 06:21 AM
Car: 91 Z28
your right i coulda woulda and shoulda got a poly mount. oh well, thinking about things in retrospect for a moment... shoulda put in a 6 speed instead of a 700-r4
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
mustangman65_79
Apr 14, 2017 05:37 PM
dhonda200
Aug 11, 2015 11:50 PM
