T-5 to 700R4
Old Aug 8, 2006 | 02:22 PM
litemanmiller's Avatar
T-5 to 700R4
I was wondering what would someone have to do to go about converting a T-5 car to a 700R4? Do I need a special tranny controller if I dont have the automatic tranny hookups?
TJ
Old Aug 8, 2006 | 02:39 PM
brutalform's Avatar
Check out this link.
https://www.thirdgen.org/forums/elec...wiring+diagram
You can pick up the lock up switch that goes through the hole in the brake pedal bracket, from a GM dealer.
Try to get a used stock shifter, as it will most likely have the neutral switch on it. I'm sure you will be able to find one with the cable as well. Then, just drill a hole in the tunnel for the cable, and fab up a plate that you can screw to the hole in the tunnel. You can use the existing screws from your manual rubber boot. The stock shifter will fit right in the area, where it normally would on a auto equipped car.
You will need a prom from an automatic equipped car also. That way the converter will lock/unlock at the correct MPH.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
