Having trouble with 700r4 shiftpoints.
Old Aug 9, 2006 | 01:06 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I just swapped from tpi to carb and now im having some shift point problems. first, it shifts a little too late when normal driving, and also it shifts way too early at wot...like 3750 at the latest. is this a tv cable problem? maybe the new throttle brakcet? throttle return spring not hooked up right? i might not even be getting full throttle from putting the pedal to the floor...there might be some more throw left in it. either way it feels a little late and a little hard on all the shifts (not like a bang, but still throws you back). maybe im just used to driving my other car (hard shift thing), but i can tell the tranny should be shifting and it waits a couple hundred rpms with almost no acceleration.
Old Aug 9, 2006 | 04:07 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
definately check that tv cable, that was the problem with mine that i fixed today, it wanted to shift around 3000 even 3500 sometimes, today i couldnt even get 4th gear until i fixed it
Old Aug 9, 2006 | 05:36 PM
camarodubs's Avatar
Car: 1987 camaro
Engine: gm goodwrench crate 350 mild
Axle/Gears: 28 spline 7.625 10 bolt w/273
Man I got that same problem on my 88 camaro that I swapped from tbi to carb and I have the shifting issue. I made me a new bracket to hook the cables to by cutting and welding some extra lenth to the holes that the cables hook through. I would just like to know the right bracket to buy that would fix that problem and if I should buy the geometry corrector.
Old Aug 9, 2006 | 10:51 PM
ZZ4 86 Z28's Avatar
i found the one today. holley makes it, and that was my problem. too much room between the cables bracket and the throttle blade.
mrbird
Oct 20, 2015 03:43 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
