Welding axle tubes on 10-bolt rear
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
For the record ...here's a pic of a welded axle tube on a 10-bolt (7.625") rear-end.
I had mine welded with the differential, axles, etc, all in place. It would have been lighter to lift with everything gutted though. There's a plastic relief valve on the top of the differential case that will leak lube (slowly) if you turn the rear-end upside down ...be careful about that.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
sharp!
i'm saving up parts for a "bulletproof" 10 bolt myself. so far, i have a set of 3.42's haha. ended up selling my posi, will get a good one here soon.
There's a GM posi with 3.42 gears in that rear. It'll probably die an early death, but I don't really mind because that'll give me reason to get better axles
I'll do the axles and differential at the same time ...makes sense.
I'll do the axles and differential at the same time ...makes sense. Supreme Member
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Looks good. I finished up my 4th gen rear a while ago and welded them myself. Its looks pretty good. One of my first "real" welding jobs...after practicing of course. Painted with some por 15. Turned out pretty nice.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
