transmision question
Old Aug 17, 2006 | 11:59 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i have an 84camaro with a 305 and 700r4 trans. when i punch the gas it will hesitate slightly and take off like a bat outta hell. but sumtimes when im on it and it wants to take off while im goin on it already it seems it dont wanna change gears and i gotta let off and hit it again and it takes off. make sense?
Old Aug 18, 2006 | 12:46 AM
bandit908's Avatar
Car: 1983 Pontiac Firebird
Engine: 305 V8
Transmission: automatic
yea i have an 83 firebird with the same engine and trans...i have the same problem. i changed out the accelerator pump on the carb and it helped a little but i still have to let off then floor it to make it take off when i'm already moving.....it just does that for some reason- i think thats just how it is (i put in a rebuilt 700r4 in 2 years ago when the original trans let go so its a relatively new trans). i'm going to drain the trans fluid and replace it with B+M trick shift ATF and see if it actually makes any difference.
Old Aug 18, 2006 | 12:50 AM
Engine: 355
Originally Posted by bandit908
yea i have an 83 firebird with the same engine and trans...i have the same problem. i changed out the accelerator pump on the carb and it helped a little but i still have to let off then floor it to make it take off when i'm already moving.....it just does that for some reason- i think thats just how it is.
yeah its kinda pain in the *** if u ask me... wonder how to fix it?
Old Aug 22, 2006 | 12:34 PM
Engine: 355
tech support at summit said its the knockdown and it needs adjusted and the line pressure. need tranny shop to do that??
Old Aug 22, 2006 | 04:40 PM
bandit908's Avatar
Engine: 305 V8
i'm not really all that sure but i'd think a regular repair shop should be able to do that- i'd go around to any shops near you and ask around.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
