One for the 700R4 gurus
Old Sep 3, 2006 | 10:25 AM
FireBoid's Avatar
Car: 1987 Firebird, 1997 Camaro
Engine: 2.8L, 3.8L
Transmission: T5, 4L60E
I have a performance 700R4 (PATC Raptor) that is "stubbing its toe" on a 3-2 down shift (2 engaging before 3 releases) only when in manual third, not when in drive. We've replaced the billit servo with a corvette servo which helped but didn't completely eliminate the problem. Not realy a huge problem, but it's not good for the ego when you pull up to a stop light and CLUNK! Any ideas?
Old Sep 4, 2006 | 05:08 AM
Pro Built Automatics's Avatar
Try grinding 4 notches in the steel cover on the 2nd gear apply servo. Get a copy of the Trans-Go Junior instructions on this. This should eliminate or mostly eliminate the 3-2 downshift problem. Stick with the Corvette servo. There are a couple of feed holes in the separator plate that can help here if this does not solve your problem.
Old Sep 4, 2006 | 11:21 AM
FireBoid's Avatar
Engine: 2.8L, 3.8L
Thanks Pro Built. I've searched here and out in cyber space for the Junior instructions. No luck. Can you supply a link?
Old Sep 4, 2006 | 07:58 PM
Call me (909 7951876) or give me an address, and I will send them to you.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
