9 or 10 bolt
Old Sep 6, 2006 | 09:05 PM
cybertiger130's Avatar
Car: Trans-am
9 or 10 bolt
I have two rearends a 1989 that was in my trans-am w/ 135k miles on it.
It's ten bolt posi. limit slip that has a 10.625 ring gear and the gear ratio 2.73 that gear ratio has to go.
I just got a nine bolt B/W, it has a gear ratio i can live with 3.27 but the rearend looks ok still not sure if it's a posi. or lsd and it needs backing plates rotors calipers.
Iam not sure which one to sink money into.
The 10 bolt, posi limit slip is a good rearend but the gear sucks.
The nine bolt ,don't know much the rearend other than 3.27 gear and needs parts
I would like your input .
Old Sep 7, 2006 | 05:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A will provide a ton of info. Bottom line is that parts for the 9-bolt will be difficult to locate (and as a consequence may be costly). A 10-bolt with a 10.625?
JamesC
Old Sep 7, 2006 | 10:12 AM
Car: Trans-am
That's what it says on the ring gear, Also thanks for the link.
Michael
Old Sep 7, 2006 | 10:20 AM
ede's Avatar
ede
you must have the only 10.62 ring gear GM ever made in the 10 bolts, even the 12 bolts went that big. there's not alot of differance between limited slip and posi, other than the spelling. again a search would provide you with more info than you could keep up with
Old Sep 7, 2006 | 03:15 PM
Car: Trans-am
Iam going to be removing it soon I will double check and repost it.
Michael
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
