Bad knock in drive gear? u guys got it?
Old Sep 8, 2006 | 11:27 PM
seymourless's Avatar
stock tranny, i just got it rebuilt with a shift kit and corvette servo. b4 i got it done there was a bad knock from the tranny, only when in regular drive gear when i would slow down and it would shift down into 1st, there is a knock and jerk coming from the tranny. with it rebuilt, it still does it...so i asked the tranny store to try and fix it, and so they reduced the pressure in the tranny which didnt fix the problem all that good and now my acceleration is now slower. they will be putting the pressure set back to how i got it after rebulding in a couple of days it which is good...my main question is does anyone else have this problem with a 700r4 tranny? overdrive its fine with downshifting, just the reg drive with the 3 gears that does it with downshifting into 1st.
any help or explanations would be great
thanks
Old Sep 9, 2006 | 12:11 AM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
What else could it be?
Are you sure it is in the tranny? Were the u-joints changed with the tranny rebuild? Could it be anything in the rear?
If it is in the tranny, I would keep pushing at the tranny shop to get it right...
Old Sep 10, 2006 | 01:52 AM
at first they thought it was the rear end but then they changed their opinions....is there anyway i can tell from under the car if its the rear axle? i jus think its fishy that they tell me it only does it in d because there is only 3 gears and the rpms go higher, when ive had it in 2nd goin 50 and it did not knock at all......
Old Sep 10, 2006 | 06:05 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
sounds kinda like a cracked flexplate, did they re-install the old one, it could have had a hairline crack that they missed
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
jharrison5
Aug 19, 2015 05:53 PM
86IROC112
Aug 17, 2015 02:00 PM
gwade12
Aug 8, 2015 08:17 AM
