rear end ?
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The number of bolts is just something used to conveniently identify the rear, it doesn't directly indicate the strength. GM has even used a number of different 10 bolt rears over the years, and the one used in the early thirgens is by far the weakest.
Third and fourth generation 10 bolt rears have 7.5" or 7.625" diameter ring gears. To some extent, the size of the ring gear indicates the strength of the transmission. Early thirdgen rears also have smaller 26 spline axles, while later thirdgen and fourthgen rears use stringer 28 spline axles.
The other stock rear used was the 9 bolt, with a 7.75" ring gear. For a lot of other reasons, the 9 bolt is stronger than the 10 bolt, but parts are much harder to find.
GM also offered a Dana 44 rear end that wasn't used in factory cars, but could be bought from the performance parts catalog. It uses an 8.5" ring gear.
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
GM also offered a Dana 44 rear end that wasn't used in factory cars, but could be bought from the performance parts catalog. It uses an 8.5" ring gear.[/QUOTE]
Can we say it's a second gen diff. into a third gen !!!
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
what rear does my august 89 born 90 iroc have? ive been told august and september are the last of the 9 bolt
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
