Help with Pinion Rotating Torque
Old Sep 18, 2006 | 09:51 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Well....I did most everything right with the pinion seal install, but I overran the nut down. I have read a bit about how to fix this and I'd rather try to DIY it before my mechanic clears out his shop for me.
I've read that with a used bearing, I need between 10-19 inch pounds of rotating torque on the pinion without the ring gear installed. I'm not planning on taking my stuff apart, so can someone tell me what that spec should be with the ring gear installed. Should I remove the wheels and brake drum too? Do I need to remove axles? I want to remove as little as possible and get as correct a measurement as I can.
Thanks..
Eric
Old Sep 18, 2006 | 10:15 AM
ede's Avatar
ede
you should of checked befoer you replaced parts. it's also very very foolish to back off the nut and the sleeve. if you went too far i'd swap in a new sleeve, and a new nut since they're one use too.
Old Sep 18, 2006 | 11:29 AM
BOSS 357's Avatar
Engine: 357 SBC TPI
Would that mean disassembling the whole gear setup? Or can I just replace the crush? Yes I am new to this but I'd like to figure this all out so I don't so this again.
Old Sep 18, 2006 | 02:26 PM
ede's Avatar
ede
you'd need to pull the carrier and remove the pinion. i'd use a solid spacer instead of the sleeve.
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
