Strange 12-bolt owners inside please
Car: Used to drive a camaro
For those of you who are using Strange 12bolt rears and disc brakes.....what did you do for a caliper bracket? I spoke to Strange this morning and they said that my 91's rear disc brakes can't be used. I have 1LE brakes and would like to keep them. Did you guys fab up a caliper bracket and use that in place of Strange's retaining plate on the rear end? BTW, I bought the 82-92 rear, not the 93+.
Help appreciated.
Help appreciated.
Update to situation (Moderators bump to brake board if it makes more sense)
I've taken the (4) bolts out of the 91 10bolt disc rear caliper mount plate and measured the mounting holes and center hole dia. Looking at the Strange 12bolt rear everything NOW looks like it will work. I have no way of actually finding out without removing the axles from both rears to swap the 10bolt caliper plates over to the 12bolt. What are peoples experience trying to use rear 1LE brakes on a 82-92 strange 12bolt??
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Re: Strange 12-bolt owners inside please
Did any one verify this?!
I thought the 93-97 plates come standard with the axle, which are the same as the stock 89-92 10 bolt rear disc brackets. Or do you need to get the optional aluminum plates (OPRG12)that will allow the brakes to bolt up?
82-92 Strange 12 bolt PRG200
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Help appreciated.
Help appreciated.
For more info go here...
Refer to post 6 & 7..
https://www.thirdgen.org/forums/tran...ht=counterbore
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
if its like my 12 bolt with the ford bearing housing just have the backing plates machined. then redrill the bolt housing pattern. that way you dont have to space anything out.
84 TA NV
Sep 6, 2015 08:02 PM
