ok ive found a deal on a 350 turbo trans, built trans, hardened sprag, shift kit, with a 4000 converter
never been ran
it is a long tail tranny. is this the type of 350 they swap to the thirdgens?
now i have noticed the trans is manual shift which is cool i dont mind that but i noticed the tailhousing doesnt have the provision for the speedo gear, Is there a way i can add that or just swap it out? swap the tailhousing?
ive looked at t56s all day but 2100 to do a 6speed swap as opposed to having a stalled auto that will be more consistant and probably faster just doesnt make sense. plus im tired of all the hydraulic %%%%
where do i get a crossmember, and a driveshaft, plus a torque arm mount for this?
__________________
never been ran
__________________
i pm'ed you . summit and jegs sell the torque arm mount or you can get sphon crossmember with a mount but are a little expensive
91 Drag,
Please post that info for all of us. I'm wondering about this also.
you can use the driveshaft from a car with a 200 transmission as long as you use the long tailshaft th350 . ive just have always modfied the 700r4 crossmember to work .
