700r4 problems...
Old Oct 2, 2006 | 04:58 PM
Dan89RS's Avatar
Car: 89 camaro rs, open k&n, 80 series, air delete
Engine: 305/5.0L tbi
700r4 problems...
my symptons are: while under throttle, between shifts theres about 1 full second of rev b4 the higher gear is engaged. also, the day i concluded shes non-driveable there was alot of throttle and no go; with the occasional +4000rpm/30-40mph movement under light throttle; at idle (in any gear) theres a distinct buzzing coming from the case itself. tranny fluid still has a little color and doesnt smell burnt; for last ~10k miles the vss (24) code has thrown my ses light a few times per week (i was told not worry about it. mistake? i think so.) my question now is WTF? lol. plz help.
ps. 89rs lo3 has a 700r4 and not the 4l60 right? (friend brought this question to my mind)
Old Oct 2, 2006 | 07:04 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
to answer your first question....the tranny is done.. its time for a rebuild. it seems to be slipping and when it comes to trannys there not really back yard fixable....unless your really feel like an adventure... now i dont know now much racing you do but if it was me i would save up and take it to a very reputable tranny shop. trannys are very complex to the average person. now when it comes to your friends car...check the firebird camero data on this site...it should tell you
Old Oct 2, 2006 | 07:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A 700R4 and a 4L60 is the same tranny but with a different name. GM changed the name in 1990. This is not to be confused with the 4L60E, which the 94 and newer f-bodies got.
Old Oct 2, 2006 | 09:20 PM
Dan89RS's Avatar
thanks. i was aware the difference in the 4l60 and the 4l60e; just not the difference in the 700r4 and 4l60. thanks.
thanks for input dave. btw this is my get around car. lol. far from race-worthy. (remember... LO3)
more input would be awesome still.
Old Oct 9, 2006 | 11:19 AM
Dan89RS's Avatar
what do u guys think about my vss error? could that have had an eefect that caused this? would i be dumb not to get a new vss when i get my new tranny? thanks.
Old Oct 24, 2006 | 10:34 PM
Dan89RS's Avatar
it took a while but we finally got hte chance to drop my tranny. not too many problems. one thing that has me worried is a 2-wire plug that wasnt in use. my searchs have made me conclude that a) this wire would go to to my vss (however i have a cable-driven speedo; maybe the wire's there and was used on a different yr model); or b) it goes to something completely diff and i shouldnt worry.
what do u think?
Old Feb 19, 2007 | 11:51 AM
MyMaro89RS's Avatar
Car: 89 Camaro RS
Engine: 5.0 TBI
Axle/Gears: stock
I know this is an old thread but it is my problem also. I am wondering if anyone has any more info on dans last post. I too have a 700r4 with a speedometer cable and a 2 wire plug not in use on my 89 camaro. i have some intermittent stalling problems when i shift from park to reverse or drive. occassinaly the computer can not catch the idle and it drops too low and stalls. from my reading i have learned that this can be caused by no VSS however my speedo works fine (not sure about the cruise i haven't had a chance to check it). my haynes manual says that pre 85 f bodies have a vss integrated into the cluster and the 85 and later models have them integrated into the tailshaft of the trans. i wonder if this has anything to do with my occasional stalling.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
