Rear end question.. (Stupid one)
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
On the type of rears that come in 89 Camaros, is it possible to just bolt in a posi unit, like you do on Chyrslers??? I tried to search, but am not putting the search in right...What is involed in converting an open rear to limited slip....Thank you very much for any help on this issue...Tom
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
It depends on the rear end gears that you have or want. There is a two series carrier for 3.08and lower and a 3 series carrier for 3.23 and higher. If you have the correct carrier for your ring gear and pinion you can put in a posi with the proper set up and no probs. I have a 2002 carrier in my 91 rs, I am running 3.73 gears
Car: 89 RS, 92 Z28
Ok, guys...
Thank you very much for the help...I will do what I can to idenify what I have in the car....She sure need some more traction.......If anyone has any pointers, im sure listening......
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Most likely you have the 7.625" 10-bolt GM Corporate rear end. This rear is similar in design to a Dana rear that you might have seen in Chryslers before. The major difference is that the shims for the backlash go on the ends of the carrier races, not under the bearings like in a Dana. The rear is easy to identify because it will have 10 bolts holding the cover on. These rears are fairly easy to work on, but not very strong. If you want to lay down some power I'd highly suggest a girdle style cover like the ones sold by TA Performance. I'd also suggest going with an aftermarket posi unit, like an Eaton. These are stronger than the OEM units, and they are getting hard to find for cheap (it's been five years since the last F-body rolled off the line after all). Definately upgrade to 28 spline axels if you're switching the differential.
Car: 89 RS, 92 Z28
Well TKO, thanks alot...I will check it out.......
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
