700r slides into od now????
Old Oct 13, 2006 | 11:07 PM
DeHoyos's Avatar
Car: 87 IROC
Engine: "400"
Transmission: Whiplash unit from CVT
Axle/Gears: Bolt-in 9" Moser
The trans was rebuilt professionally and worked absolutely fine. I put maybe 3K miles on it, then the car sat for about 3 years. After I have the stroker motor in it and a 3500 stall, its acting up. If I'm slowly accelerating in OD it slides into 4th. Never did this before. Is this possibly a kickdown issue? I haven't tried letting the car upshift by itself @ WOT. Want to straighten this out before I burn it up.
Old Oct 14, 2006 | 10:28 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
forward cluthes(overdrive) are burning up (slipping). check your tv adjustment and fuid level. more than likely the trans will need to come out.
Old Oct 14, 2006 | 04:20 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Push the servo cover in and out. You may need to put a piece of wood against the tunnel and use a prybar to move the cover. If it moves in and out more than an 1/8 of an inch, servo pin may be too short.
Old Oct 14, 2006 | 08:59 PM
DeHoyos's Avatar
Car: 87 IROC
Engine: "400"
I'm gonna recheck the tv cable in the am. It's not like it gradually started doing this. It shifted fine when I last drove it. I launched it today from a stop in low 1 and it shifted into 2nd by itself. I've never known it to do that. Could it be because I no longer have the computer in the car?
Old Oct 18, 2006 | 08:37 PM
DeHoyos's Avatar
Car: 87 IROC
Engine: "400"
UPDATE: I had the tv cable adjusted all the way back and it still wasn't enough. Took it to a trans shop where my buddy works and we ended up putting split-shot on the front of the cable to take up the slack. Now the only thing that's slippin' are them damn drag radials when I romp on it.
84z96L31vortec
Aug 20, 2017 12:16 AM
timonator
Sep 30, 2015 12:52 PM
Youngs92
Sep 23, 2015 11:29 AM
DARKmj16
Sep 9, 2015 04:07 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
