wtf wtf, about to give up
Old Oct 19, 2006 | 06:38 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
trying to do the auto to manual swap. i cant seem to find the right flywheel. i order 2 for a 85 camaro, they were wrong ones. so then i order 1 for a 87 and 1 for a 90 camaro still the wrong one. all 4 look the same, wtf. im pretty sure it a once pierce rear main seal. the center hole is about 2in on the flexplate. on the wrong flywheels they are 2.5in. CAN ANYONE HELP, PLEASE!
Old Oct 20, 2006 | 05:52 AM
jayk2k3's Avatar
Car: 85 camaro z28
anyone???
Old Oct 20, 2006 | 10:51 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Check the casting number on the block. This will tell you if you have a 1 or 2 pc seal. You can check the casting number on the crank also.
or
The bolt circle on a 1 pc seal crank is 3".
The bolt circle for a 2 pc seal crank is 3.58".
Gary
Kingston,NH
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Linson
Oct 1, 2015 09:50 PM
