overdrive
Old Oct 23, 2006 | 04:39 PM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
overdrive
i just put a 355 in my iroc;carb, from a 305 tpi the guy that put it in took out the vacuum canister.i had a gm dealer put in the lockup kit for the 700r4 when i left the shop i went to 80 before it shifted to o.d when i got home i adjusted the cable and it shifted around 55 but the slitest bit on the gas and it goes in and out.i have a xe 268 that is suppose to have good vacuum.do i need a vacuum canister for my overdrive to work right or did i get screwed by another clown
Old Oct 23, 2006 | 11:52 PM
Pro Built Automatics's Avatar
You have changed this from an injection to carb? The TV cable geometry relationship has changed most likely to have caused the 3-4 shift to be late. This will have to be addressed "first". The torque converter clutch lockup kit, is it operated by vacuum?
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
