Will this posi unit work?
Old Oct 27, 2006 | 03:38 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
I have a 92 camaro RS 5.0L with an open 2.73 stock 10 bolt rear end. I have a chance to pick up a stock gm posi and 3.73 gears from a 95 camaro Z28 with a 10 bolt that are for a 28 spline axle for $50.
From my research, I know that in my RS, I have a series 2 carrier in there now and I think I have 28 spline axles (they are whatever is stock for this car.) This unit should fit if it is the posi chunk and the gears to go with it right?
I think it should, but i just want someone to reassure me.
Old Oct 27, 2006 | 06:01 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
anyone?
Old Oct 27, 2006 | 06:36 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
If the posi unit from the '95 is a 3 series unit, all you have to do is make sure the axels in your '92 are 28 spline and you are home free
Old Oct 27, 2006 | 06:57 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Did 95 Z28's come with series 2 carriers? If so, how would I verify that it is a series 3? Is there a number stamped on the unit somewhere?
The reason I ask is because the unit is no longer in the vehicle. Its on his workbench.
And stock axles in a 92 RS should be 28 spline right?
Old Oct 27, 2006 | 07:21 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
A factory 95 Z should have a 3 series carrier. Your 92 RS F Body if stock will have 28 spline axles but a 2 series carrier. The 3 series carrier from a 95 will work in a 92 housing.
Old Oct 27, 2006 | 07:38 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Ahhhh. Short, sweet, and to the point. You answered all of my questions. Thanks a million dude.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
