I want to know...
Old Oct 28, 2006 | 11:41 PM
BobbyRod's Avatar
Car: CAMARO RS 25th Anniversary Z03
Engine: L03 V8 5.0
Transmission: THM 700 R4
Axle/Gears: 2.73 OPEN
I want to know...
OK, I went to a junk yard and found some rearends w/disc brakes for my 92 RS, they´re offering me a good deal but my question is: How can I know if they have a Posi on it and which gear is inside??? and what kind of rear disc brakes are???? I´m triying to get the better for my bucks!! Thanx in advance.
May the force be whit you...
B-Rod.
Old Oct 29, 2006 | 05:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the disc rear in question looks like the one in the following link, it's from an 82-88 car--not the best brakes, but with the "fix' kit acceptable, IMO. As for the posi, check the second page of the link. You'll see what the posi generally looks like.
https://www.thirdgen.org/forums/tran...ighlight=gears
If the rear calipers are finned alum, the rear is from an 89-92 car and is very desirable. To see those, check below:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Here's how to determinne what ratio the rear is (jerk the diff cover and look): numbers are stamped on the ring and pinion:
41 : 15 = 2.73
41 : 14 = 2.93
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Old Oct 29, 2006 | 10:49 AM
BobbyRod's Avatar
Engine: L03 V8 5.0
That`s the good thing of getting an answer from somebody who really knows. THANK YOU!!!
Yet another thing, those 82-88 or 89-92 discs and caliper would fit in stock 15 in. Wheels???
Old Oct 29, 2006 | 11:26 AM
JamesC's Avatar
The front rotors currently on your car will be the same size as the 82-88 rear rotors, about 10.5 inches, so no fitment problems for your 15's. The rotors on the 89-92 J65 rear, however, are about 11.7 inches. These latter rotors/calipers will fit under an IROC 16-inch wheel, but I'm unsure about 15's.
JamesC
Old Oct 31, 2006 | 02:46 AM
Pat Hall's Avatar
The 89-92 style discs will fit under the stock, five spoke 15x7 Camaro rims. It's close, but they fit. I run my 15x7's with snow tires in the winter on mine with a 91 GTA PBR disc rear.
luvofjah
Aug 29, 2015 08:33 PM
CORV3TT3
Aug 23, 2015 11:26 AM
[-sLaYeR-]
Jul 26, 2002 11:39 AM
Xenodrgn
Oct 22, 2001 12:26 PM
Xenodrgn
Oct 22, 2001 10:33 AM
