speed sensor
Car: 1984 Trans Am WS6
Engine: 305 HO
Transmission: TH700R4
Axle/Gears: 87 Borg warner 3.27
speed sensor
since I changed my 84 rear end with a 86 borg warner with a different ratio (3.27) do I need to change the speed sensor as well?
thanks
thanks
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
no there is no reason to change you speed sensor, you may have to change the speedo gears to correct you speedometer if the axle you installed has a different ratio that the last one
