b&M shift - hard to shift
Old Nov 3, 2006 | 09:17 PM
graphicideas1's Avatar
I just installed my shifter - it is hard to get out of park - any help?
Old Nov 4, 2006 | 10:59 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Is this a B&M Ratchet shifter?? If so I think thats just how they are. I have been using my ratchet shifter for over a year and its still stiff when trying to get out of park.
Old Nov 5, 2006 | 03:28 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I've had mine in for about a year now myself, and I find that it is getting easier to pull out of park as it gets broke in. Make sure you have no hard bends in the cable, that will make it hard also. I think these shifters do pull kind of hard out of park anyway, but mine is getting better with age and use..
Old Nov 9, 2006 | 10:50 PM
kcr357's Avatar
Car: S10
Engine: 383
Transmission: th 400
Axle/Gears: Stocker 10 bolt w/4:11's
Any problems downshifting from drive? When my car is running the shifter won't "grab" enough to shift into second. I have to physically pull on the plate that the cable is mounted on and help it to shift. When the car is not running it works fine. I installed a transgo shift reprogrammer for full manual shifts- could that be the problem?
Old Nov 10, 2006 | 01:01 AM
sixpackmtrspts's Avatar
may need to adjust the cable a little bit.
Old Nov 10, 2006 | 04:08 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
I agree with what was said above, that you are going to need to fine tune the adjustment on your cable, go to the instructions for adjustment that came with the shifter and adjust accordingly. I have no issues with up shifts or downshifts on mine.
Old Nov 10, 2006 | 05:21 PM
kcr357's Avatar
Car: S10
Engine: 383
I just found out the "vacuum modulator", whatever that is, needs to be hooked up despite having a full manual valve body.
Old Nov 11, 2006 | 02:53 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if you have a 700r4, you don't have a vacuum modulator.
Old Nov 14, 2006 | 10:46 AM
3rd-gen junkie's Avatar
Car: 1991 Camaro RS
Engine: L03 5.0L
Axle/Gears: 3.08
Maybe I'm behind the times, but i thunk only Ford C4's and C6's and maybe the E4OD only had vacuum modulators? Sure you don't have a mustang there, chief?
Old Nov 14, 2006 | 11:16 AM
87zjeff's Avatar
plenty of chevy trannys had vacuum modulators. TH350,TH400,TH440-t4,TH125&c. E4OD doesn't have a vacuum modulator though.
junior419
Apr 7, 2025 11:35 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Breazlan
Sep 25, 2015 11:20 AM
TheTraut88
Sep 7, 2015 05:22 PM
