Parts needed for a manual to automatic swap
Old Nov 6, 2006 | 06:03 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
I am about to do a swap from my WC T-5 to a 700R4. I was wanting to get everyone’s ideas on what will be needed. So far my list includes...
-Transmission
-Torque converter
-lockup wiring and controller (Can I use the PCM from the auto car?)
-flex plate
-starter
-cross member
-TV cable and mounting brackets
-cooler lines (Can I use an aftermarket cooler instead of going through the radiator?)
-center console and shifter
-driveshaft? (I believe that the T-5 and 700R4 use the same one but...)
-VSS (Same as T-5?)
Let me know if I am missing anything and what you think. The reason I am going this way is for racing. I love driving the stick on the street but I suck at the track. Not the trans's fault but I would rather just hit the gas and concentrate on driving rather than shifting. Plus a trans brake would really kick ***! Right now the only thing kicking *** is my car and unfortunately the *** it’s kicking is mine with these pathetic 60' times!
Also, I have found a few others looking to do the same thing so you would be helping not just me but a community of your brethren.
Old Nov 7, 2006 | 05:22 PM
Superior Styles's Avatar
Car: 1986 CHEVY CAMARO IROC-Z
Engine: Twin Turbo 383 (1190hp 1249Tq)
Transmission: 1000 rated T56 6 speed manual
Axle/Gears: 3.73 Posi & mini spool & 28 spline
DUDE UR LIST IS RIGHT !! DUDE ILL GIVE A FREE 700R4 BUILT TO SUPPORT 500HP I JUST GOT IT DONE 2 MONTHS AGO AND ITS ONLY HAS 22 MILES ON IT CAUSE I CHANGED TO A TH350 AS SOON AS I BROUGHT IT SO MY GIVE AWAY IS FOR ALL YOUR T5 TRANSMISSION PEDELS SLAVE CYLINDER AND FLYWHEEL AND SHIFTER PLATE LET ME KNOW IM ON AIM OR YAHOO MESSENGER WITH THE NAME VENOM3971 CONTACT ME ASAP TO LET ME KNOW
jhawkeye
May 25, 2022 06:33 PM
midge54
Jan 29, 2017 07:00 PM
IROCZ1989
Jan 24, 2016 03:55 PM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
