400 turbo trans
Old Nov 10, 2006 | 08:14 PM
raptor350101's Avatar
Car: 82 z28 camaro
Transmission: auto
Axle/Gears: 4.10 posi
400 turbo trans
I have an 82 camaro with an automatic transmission. i was wondering if it is possible to put in a 400 turbo trans in place of it.... if so wat all would i have to do
Old Nov 10, 2006 | 08:49 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Read the sticky at the top of the page. It is a very complete post that will help you alot.
Old Nov 12, 2006 | 11:35 AM
kcr357's Avatar
Car: S10
Engine: 383
Transmission: th 400
Axle/Gears: Stocker 10 bolt w/4:11's
http://http://www.jegs.com/webapp/wc...15557_-1_10531
This is the kit I used, made it much easier. If you have a th400 with the bolt on yolk, you will need a driveshaft with a slip joint. Hurst recommends 43 7/8" from u joint centers, but you should measure the distance to make sure. That is all I can think of that wasn't in the sticky.
Why the th400 with a 305? Are you planning a swap soon?
Old Nov 13, 2006 | 02:38 PM
Shagwell's Avatar
Car: projects.......
a 305, as 4.10 gear and T400? I'm hoping you're planning a motor swap soon, and that this is not gonna be a driver......
- anyhow, all the info is in the sticky, a search will also net you a lot of info.
bjpotter
Jan 22, 2019 12:27 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
BlackphantomZ28
Apr 24, 2016 08:14 AM
camaro71633
Sep 1, 2015 10:24 AM
