T.V. Cable Adjustment?
Old Nov 11, 2006 | 01:59 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
When Car Craft had my Formula, they installed a Nitrous Works kit, which mounts inbetween the throttle body, and the plenum. I'm wondering if this has any affect on the length of the T.V. cable. The reason that I'm asking this is I can't get the adjustment down. I have tried the "push & click" method, but when it's done that way, under normal driving, the shifts are late or not at all unless I lift off the throttle and let it shift then give it gas again, but the shifts are firm & positive. When I pull the cable out a couple more clicks, the shifting is really weak, and the gears don't feel like they grab, but the shifting itself under normal driving is good.
The nitrous plate is about 1/2" thick so it moves the ends of the throttle cable, and T.V. cable out that much further from the mount on the plenum.
Does anyone have an idea of how to fix this?
I've contacted Nitrous Works, and they had no clue about this problem.
I just rebuilt the trans and now the fluid smells burnt. I don't want to have to rebuild it again.
Old Nov 13, 2006 | 10:31 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
the way i was showen by a gm trans tech was push the button on cable in to unlock the cable push cablle all the way back release lock get in car give the gas pedal a push to full open cable should self adjust to correct postion
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
