Slow response on gas pedal
Old Nov 24, 2006 | 10:33 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
I have a 1986 Trans AM. V8 5.0 FI TPI. I am the 3rd owner and the previous 2 I can't say treated the car well. The automatic transmission was rebuilt before I bought the car. I get slow response when I press on the gas pedal trying to get from 1-10MPH. After 10MPH give or take the car takes off and drives fine. Is this normal for an old car like this and is there any kind of matenience I can do or tune up or fluid change that will help me. Anytihng besides change my transmission or could it be something besides my transmission? Any suggestions would be appreciated.
Thanks,
RB
Old Nov 24, 2006 | 11:19 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
do's it run smooth?
In general a tune up cant hurt, that and a oil change
any SES lights coming on?
Old Nov 24, 2006 | 11:47 AM
Bobby_80s's Avatar
Axle/Gears: no idea
what is an SES light? Already did the oil change and new battery and new radiator, new spark plugs and decent wires were already installed before i bought it. I just don't like waiting 3seconds before I actually start mioving especially if I'm trying to get out of a parking lot before more traffic comes.
Old Nov 25, 2006 | 09:54 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
check engine light =ses
Also trans could be slipping in first gear if the motor IS OK
Old Nov 25, 2006 | 02:32 PM
Bobby_80s's Avatar
Axle/Gears: no idea
yes the engine coems on after driving for a few minutes then doesn't pop up again till i drive a little more again. A mechanic friend said it may be my distributor cap/mechanism. If its burn out or damaged or even if the wires for the spark plugs are kinda bad the car will have a similar problem to build up power to go. then the weight of the car helps push and less strain on the electrical system. I'm going to look into it. I got a 44 engine code and i'm looking it up right now.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
rsrookie
Sep 5, 2015 07:08 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
