Slow response 2
Old Nov 25, 2006 | 01:54 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Slow response 2
Hey guys,
I just want anyone who can help out to lend their own ideas. I press down on the gas pedal and it takes about 2-3 seconds before i even move. then the car it self kinda drags untill it hits about 10-15MPH then takes off and drives fine past that point on. Does anyone have any ideas or know what the problem is? And what kind of maitenence I can do to help or cure this problem. I have a 1986 Trans AM, V8 FI 5.0 TPI Automatic. Any ideas or tips would be appreciated.
Old Nov 25, 2006 | 09:31 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Sounds like the tranny is slipping in 1st.
Old Nov 25, 2006 | 09:33 AM
Bobby_80s's Avatar
Axle/Gears: no idea
the tranny has already been built, is that something a shop can fix 1st gear or am i lookin at a big problem?
Old Nov 25, 2006 | 09:40 AM
Car: 2012 Corvette
Engine: LS3
I'm not 100% sure it's that, I'm just saying that by the description you gave it kinda sounds like it's slipping in first and once it gets into second then it drives like normal.
Old Nov 25, 2006 | 09:55 AM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks, I also put a post in TPI asking about the hose lines from the plenum connecting to the cruise control. I bought the car and after changing the battery i noticed the hose spilts into two hoses from the plenum one end goes to the cruise control vacuum box or whatever you call it and the other hose ran along side the inner driverside fender and battery and was connected to nothing. I cant find anything on where it is supposed to go. Any ideas on where i can go for resources?
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
