2800 stall for 305tpi
Old Nov 25, 2006 | 11:16 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Is a 2800 stall for a 305 tpi car to much? What would be my driveability side affects? I am running a 3.73 gear and shift kit already with headers, custom exhaust with no cats, and all the misc. bolts ons. I am also running a 150 shot of nitro.
I am about out of items to install on the car without changing the motor. so the stall convertor is the last thing I can do to see how fast this 305 will go.
Anybody on hear running a 2800 stall with a 305 motor?
Old Nov 25, 2006 | 06:56 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I was using a 2500 stall with my application.
Mods are in the sig.
No ill effects from the stall
I got a tranny cooler.
Old Nov 25, 2006 | 07:05 PM
burnout88's Avatar
Car: 88 IROC
What particular stall did you go with? You have a similar setup to mine. Did you like it and did think it actually made a difference. I would appreciate your input since we have a pretty close combo. Also, what tranny cooler did you use did you have to cut the trans lines to install it.
Thanks,
Old Nov 26, 2006 | 07:46 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I got a stall from a friend that runs a tranny shop. It didn't have a brand name.
I liked the stall and it helped for sure. Best 60ft was a 1.82. Make sure that you beef up the suspension to compliment the higher stall(LCA, LCARB,)
I used a external tranny cooler along with the cooler in the rad.
I routed the fluid in the rad 1st, then to the external cooler and then back to the tranny.
Old Nov 27, 2006 | 02:21 PM
Shagwell's Avatar
Car: projects.......
2800 would deffinitely be a bit much for a stock cam. 2500 would be plenty. Either is very driveable IF you get a decent brand. The cheapies won't last under any conditions.
- I'll assume you're spraying a 150 shot of nitrous, not nitro. Two very different things........
Old Nov 27, 2006 | 08:34 PM
burnout88's Avatar
Car: 88 IROC
Thanks guys, I am spraying nitrous, not nitro. I was looking at Precision Industries stall. But based on some of our feedback I think I am going to go with a 2500 instead of a 2800.
Hotrodboba400
Dec 10, 2019 07:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
