S10 Transmission Question
Car: 1986 Firebird / 1991 Formula
Engine: 350 4BBL / 305 TPI
Transmission: 700 R4 / T 5
Axle/Gears: 9-Bolt Posi / 10 Bolt Posi
A friend of mine has a camaro that needs a transmission. He wants to know if the automatic transmission out of a 1987 chevy s10 2wd 2.8 work in an 85 chevy camaro 2.8 or are the tail shafts or other parts different or incompatible? Also, what would he need to change in order to make it work, other than the piece on the tailshaft that the torque arm mounts to?
Car: 86 Iroc 383 carb, 97 T/A WS6
I sold a 700r4 out of an 88 2.8 s10 to a guy for a 88 or 89 firebird v6 and it fit fine. I sold it to him on a sat morning and he drove it by my house that evening and said that everything matched up fine.
Seth
Seth
Pretty interesting story, considering that the T-5 in the F body is rotated 18 degrees different from the S truck version, and the S truck version's shifter pad is about 6" in front of where it should be in a F car. Also, the S truck version has no provision for the torque arm.
No, it won't work.
No, it won't work.
No, it won't work.
No, it won't work.
Who said anything about a t5, hell you can look at those and tell that theyre way different. I am talking about a 60 degree v6 700r4.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
