Rear Differential Yoke
Old Nov 25, 2006 | 11:47 AM
novatuc's Avatar
Car: 1984 Trans Am
Now that you guys (and some searching) have provided everything I need to know about the aluminum driveshaft I'm at the next step. I am guessing there is a difference in the differential yoke for the aluminum driveshaft. My rear yoke takes the u-joints with the c-clip towards the inside. By the pictures posted it looks like the aluminum shaft has the clips on the outside of the u-joint caps. If this is so, then I will need a new differential yoke to fit an aluminum shaft onto my car. Am I correct in this assumption?
Old Nov 25, 2006 | 01:59 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Unless you changed the end yoke on the diff pinion any 3rd/4th gen aluminum dr shaft yoke should bolt rigth up with no problems.
Old Nov 26, 2006 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
After selling 70+ JG1/1LE alum drive shafts, I came to the conclusion that they would fit 88-92 cars without difficulty. My 85 required another U-joint as did other members' cars which were pre-88. I used and recommended CarQuest p/n 3-3130.
JamesC
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
E Rod
Aug 28, 2015 05:17 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
red90IROCls1
Aug 25, 2015 06:56 AM
