need torque converter help
Old Dec 1, 2006 | 12:55 PM
chevycamaroiroc's Avatar
Car: 87 Chevy Camaro Iroc-z
Engine: 350tpi
Axle/Gears: 3:27 POSI
Hey i need some help i have a 87 iroc-z/700r4 tranny and a 350 smallblock mildly modded,am looking to purchase a high performance converter for my transmission,i want to get a few opinions, if the tci streetfighter will work out fine? it has 3000 stall,am looking for a converter that will give me a huge noticable performance launch off the line and better bottom end,my rear end is a 3:27 all high perofmance gears everything is brand new in the rear and am also gonna put a b&m shift kit when i decide on the torque converter,my car has headers,race wires,ported intake,ported plenum,3 inch magnaflow exhaust,3 inch y pipe,k&n's,really mild cam for now not a high lift cam smooth idle, but will be swapped shortly after the transmission work,help would be greatly appreciated thanks alot
Old Dec 1, 2006 | 01:05 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
If you're planning on a cam swap, better match it to the converter or visa versa.
Old Dec 2, 2006 | 08:16 PM
Pat Hall's Avatar
The first thing I'll advise you to do is ditch the idea of a B&M shift kit and use a Transgo kit instead. The B&M kits suck for 700r4's. The Transgo kit is vastly preferred by most people that are knowledgeable about 700r4's. As far as a converter goes, you'd probably have better luck with a Hughes, Midwest, Continental, etc. Or if you can afford it, a Vigilante, Yank, or Edge are even better choices. I've heard a lot of mediocre responses about the TCI converters in a 700r4, and B&M converters are even worse. Like Wade said, you really need to match your stall speed to the cam you're running. You'd have to be running a pretty radical cam to need a 3000 stall. The most common stall speeds are usually somewhere around 2000-2600. It's also damn expensive to get a 3000 stall converter that still retains the lockup feature, which you need for your overdrive to work properly. Do some searches on the board here and you'll find tons of posts from other members saying what type of stuff they're running.
Old Dec 2, 2006 | 09:06 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I have a 12" 2400 stall lockup, built midwest converter for sale...it has about 1100 street miles on it bought new for $400, $150 shipped to you...send me a pm if you're interested.
Old Dec 3, 2006 | 08:26 PM
Pat Hall's Avatar
Yeah, I've been eyeballing your post for the last week or so. That's a sweet deal on a good converter. If I needed one right now, I'd have already bought yours!
Old Dec 21, 2006 | 11:14 PM
jstoll's Avatar
Car: 91 Formula
If you still have that converter for sale I would be interested.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
