I can't stop the vibration
Old Jul 11, 2008 | 08:19 AM
  #101
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Re: I can't stop the vibration
Originally Posted by Auggie
Go to "Tranmissions & Drivetrain" and click on "Drivetrain Viberation! what could be causing " Read posts #11 and #34. I don't know if this is your problem but it sure worked for me.
Ok, well those posts in that thread talk about a bad torque converter. But if I'm going down the freeway, I can shift the car into neutral and shut the engine off and the vibration doesn't change. I know shutting the engine off will stop the outer portion of the TC from rotating (since it's bolted to the flywheel), and I assume shifting into neutral will stop the fan inside from rotating. Can any1 confirm that?
Old Jul 18, 2008 | 08:50 AM
  #102
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Any more ideas?? Or does any1 see any problems in my testing methods?
Old Aug 5, 2008 | 09:56 AM
  #103
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Ok, I have yet another idea... I was watching Trucks on Spike this weekend and they showed a really ez method to make sure the driveshaft angle at the trans matches the angle at the axle. They took a straight piece of stiff wire, lined it up w/ the body of the trans, and bent part of the wire till it matched the center of the driveshaft. Then they took the wire, lined up 1 end w/ the driveshaft, and lined up the other w/ the differential. Those 2 angles should be the same (as discussed earlier in this thread) and this seems like a really ez way to verify that. So hopefully I'll get some time this week to pull her out and try it.
I took my g/f out on the town Sat night... it was a beautiful day and it was perfect for cruising w/ the T-tops out and the foglights on. Then we drove home on the freeway and the vibe seemed like it was worse than ever
Old Aug 5, 2008 | 06:30 PM
  #104
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I have a similar problem, at least when I still had the car together. Mine did it at 75+ and most noticeable when I was off the gas. Seems the 4th Gen guys have the same problem. I was just over at LS1 Tech and see the same comments.
http://ls1tech.com/forums/showthread...bration&page=3
Old Aug 5, 2008 | 07:00 PM
  #105
skinny z's Avatar
I've only glanced through the postings however I didn't see any mention of the differential itself.
Worn pinions and increased backlash are common causes of vibratrions or low frequency 'humming' particularly using the tests you've described.
Old Aug 7, 2008 | 02:05 PM
  #106
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
I swapped in a complete rear axle assembly... didn't have any effect.
Old Aug 11, 2008 | 03:21 PM
  #107
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Well I put the car up on blocks and tried to measure... but of course everything looks ezr on TV -- especially since they were doing it on a partially assembled 4x4 instead of a completed assemble sports car! But if it is off, it isn't off by much... it looked the same as far as I can tell w/ the wire. Just by eyeballing it, it looks like there's just a little more of an angle from the trans to the DS than from the DS to the rear axle, but it's hard to judge that just by looking. How much of a difference in angle would it take to create that strong of a vibration?
Another thing I didn't think about is that I should have raised and lowered the rear axle -- the angles should be the same thru the travel -- becuz a more severe angle might have been ezr to measure. And I would have had more room inside the tunnel to look at the wire compared to the DS.
Old Sep 9, 2008 | 02:26 PM
  #108
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
I took my neighbor (who has had several 2nd gen Firebirds) for a ride a few days ago. He thinks that the tires are flatspotted, which is causing a low-speed vibration. That could be, but it also could be that the tires are squared off cuz the car sits so much. The tires are also old and have very little tread on them.
Then we went for a ride on the freeway and he pointed out that the driver's side of the hood vibrates a lot more than the pass side of the hood. There's also a minor side-to-side wobble in the steering wheel. So he tried to tell me that something in the front of the car is causing the whole vibration problem. Well we did have a problem w/ the caliper bolt hole on the driver's spindle getting stripped out, and we replaced it w/ a used part. So I thought that might be suspect. But it could also just be the tires... so what I did was swap the front tires from side to side. And guess what? Neither side of the hood vibrated very much and the wobble in the steering wheel was almost gone. If it was the spindle, the hood vibration would have stayed on the driver's side. If it was a rim, the hood vibration would have changed sides. But since it went away, the only explanation that makes sense is that it was a problem w/ the tire tread -- and running the tires backwards minimized the impact becuz they're not worn in in that direction.
I know it's not a problem in the front end, becuz the same vibration is present even when the car is on jackstands. But this is the 2nd time I've had some1 in the car who gets confused by the minor vibrations caused by the old tires and can't concentrate on the real vibration. So unfortunately, I think it's time to step up and spend a few hundred $$ on some tires for a car that's lucky to see 200 miles/yr While the tires are off, it will also give me the opportunity to make sure the rims themselves are causing any minor vibes. I don't want anything distracting "experts" from the actual vibration. It will also help me determine if I've made any improvements from stuff I've done or will do.
Old Sep 22, 2008 | 04:32 PM
  #109
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
I got her our again this weekend and took another shot at measuring the driveline angles -- this time w/ the rear axle all the way down. I also figured out a lot ezr way to measure. It's kinda hard to explain w/o a pic, but the driveshaft is basically an aluminum tube w/ a bracket welded to each end that holds the U-joints. As long as the distance from the weld to the center of the needle bearing caps on the bearings that are closest to the DS are the same (and they are), and the length of the bearings across the diameter of the DS are the same (and they are), then the minimum distance between the center of the needle bearing cap to the weld for the bracket should also be same. If they're not, then the only thing left that could explain the difference would be that the angle from the trans to the DS was different than the angle from the DS to the axle.
In my case however, those distances were identical. And that means the angles are identical and that is not the cause of the vibration.
Old Sep 22, 2008 | 04:56 PM
  #110
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Syco, I hate to sound like a broken record but I have done all the things that you said that you are trying and doing. I even installed an entire rearend but when I changed my torque converter to a non-lockup "ALL" the vibs went away. My car is as smooth as silck. Someone has to try a torque converter !!
Auggie
Old Oct 7, 2008 | 03:33 PM
  #111
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Syco, I hate to sound like a broken record but I have done all the things that you said that you are trying and doing. I even installed an entire rearend but when I changed my torque converter to a non-lockup "ALL" the vibs went away. My car is as smooth as silck. Someone has to try a torque converter !! Auggie
Yeah u'r right... especially given my new theory that there are multiple causes for the vibration in my car.
So, where do I get a non-lockup torque converter? Is it the lockup mechanism itself that goes bad and causes the vibe? I mean, it's not as simple as just disconnecting the wiring so it doesn't lock up, right?
Old Oct 7, 2008 | 03:43 PM
  #112
Auggie's Avatar
Well its been a few years but all I did was buy a rebuilt torque converter for $150 I think from NAPA (I don't remember what it was used on) an then called Art Carr Tranmissions and ordered a kit to reroute the oil. You might want to go to there web site or call them for the info.
Auggie
Old Oct 13, 2008 | 02:59 AM
  #113
Dr G's Avatar
I know this may sound stupid but I will get a real bad violent viberation at hwy speeds when I have the drivers side window down on a windy day. Has anyone else had that happen? Roll up the window and its golden. On another note I had all these same viberation proublems and cured all my viberations by going to a non-lockup torque converter. You can't belive how good you feel when you go down the road viberation free after chasing them viberations for two years.
Auggie
Guys, listen to Auggie about the torque convertor suggestion. Also, check out my thread that he mentions in one of his posts above. A new TC solved my vibration issue.
Old Oct 22, 2008 | 09:26 AM
  #114
skinny z's Avatar
Check out my post under vibration.
I can only comment on my combination ( 700R4 with lockup convertor ) but it seems it's not the torque convertor itself ( I experimented with 3 convertors and 3 different 700's ) but the relationship between the convertor and flexplate. There's even a test procedure in the GM manual called 'Flywheel Assembly/Torque Convertor Clutch Vibration Test'. Decouple the convertor , rotate it 120 degrees and reconnect. Repeat if necessary.
After my latest install, I seem to have hit upon the best relationship between the two. I guess that even though both components are balanced individually, there is a stack up of tolerances that results in a slightly unbalanced condition with a resulting vibration.
Wouldn't have believed it if it didn't happen to me. And I've been at this for YEARS!
Old Oct 30, 2008 | 02:46 PM
  #115
gemini's Avatar
have an '86 T/A with a 350 backed with a t-5. everyday driving there are no vibrations and up to 65-70 everything is fine too. at 75+ it vibrates the majority of the interior or whole body, however you want to look at it. the dash vibrates pretty bad too. has 4.11s in it. only other suspension thing i've changed is to put relocation brackets on it and have also recently replaced the front struts. has had this problem with three sets of tires. if i let off and put it in neutral at 75+ it still vibrates so i dont think its a motor issue. everyone else seems to have similar problems but i didnt want to just start replacing everything left and right and not get anywhere with the problem. is there one thing anyone would recommend that i try to replace first? thanks !
Old Nov 1, 2008 | 03:39 PM
  #116
raven0840's Avatar
Car: '83 Camaro Z-28
Engine: 350 Crossfire
Axle/Gears: 3.23 posi
My '83 had a nasty highway vibe. It started at about 2250, then got steadily worse, REALLY bad at about 2400, then practically gone at 2600. T-5 trans 2.73 open rear. Not sure about an exact speed but figure it was between 65-75mph judging by timing milemarkers (speedo doesn't work).
I fixed this by installing a pilot bushing cuz my mechanic didn't. Whoops. Anyway, if your vibe isn't TERRIBLE and you have a stick, that's one possibility.
I know a couple of guys who worked on vibe problems in this thread did replace torque arms, but if you have a bent one, it'll hold your rear axle at a bad angle. Just a thought.
Old Dec 15, 2008 | 03:36 AM
  #117
darkride86T/A's Avatar
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
I've got a vibration also with my Iroc. My vibe is RPM specific, 1600-1800 RPM. It doesn't do it in park or neutral, only under load. And get this, it does it only when I bear to the left. It's fine while going straight or bearing to the right. I took the car to the shop last week and they drove the car and put it up on the lift and said it could possibly be my D.S. needs to be balanced. I should also note, that before I took the car to the shop it would vibrate at the above mentioned RPM under initial acceleration and at highway speed, however, if I went right or left the vibes went away. I've had the transmission mount replaced (stock rubber) and the vibes went away for a week. A co-worker of mine suggested sagging motor mounts. The vibe has progressively gotten better with the tranny mount being replaced and having the guys at the shop looking at it( and they didn't do anything to it). I've got Mastercraft tires(225/60hr15), Edelbrock TES headers and a Flowmaster American Thunder cat-back on the car and the vibe sounds like exhaust components rubbing against the k-frame. I feel it in the tranny tunnel, seat, and steering wheel(slightly). I'm wondering if it's suspension, mounts, rear-end, tires, wheel bearings or exhaust. Any suggestions are welcome and appreciated. Sorry for the long post, but I didn't want to leave any info out.
Old Dec 15, 2008 | 11:55 PM
  #118
bump
Old Dec 16, 2008 | 01:05 PM
  #119
bump
Old Dec 16, 2008 | 08:33 PM
  #120
GT150's Avatar
Car: 1988 IROC-Z
Transmission: 5 speed
Axle/Gears: 3.08 posi
My 88 IROC with a 305 5speed has a vibration at 3500 to 4000 rpms, then it goes away. Dosent matter the speed its only when I hit those certain rpms. I had an EC trans mount and changed it to a stock rubber one, no improvement.
I have run the car while parked and just slowly brought the rpms up to 3500 and it seems the vibration is there, Can it be from the muffler which is a chambered Hooker system?
My axles also seem to have some excesive end play.
I think this tread should be kept going
Mike
Old Dec 17, 2008 | 12:02 AM
  #121
little Potato's Avatar
Car: 71 chevelle, 73 camaro, 94 probe
Engine: 408 bbc, 360 sbc, 2.5l v-6
Transmission: 4spd, 3spd, 5spd
Axle/Gears: 10 bolt 4:10, 10 bolt 3:42, stock
Driveshaft, wheels, tires, rear end, and suspension will cause speed related vibrations. Since you said that you can hear the exhaust hitting something I would change both motor mounts and check the whole exhaust system for proper clearance. It should be at least 1/2" away from anything.
Rob
Old Dec 17, 2008 | 02:53 AM
  #122
The driver side header flange looks like it's maybe an 1/8 to 1/4 inch away from the k-frame. I was thiking motor mounts as well, but when put the car in gear with my foot on the break and give it a little gas, the motor doesn't **** up to one side like I thought a bad mount would do. My driver side front wheel bearing is loose and has alot of freeplay in it(the left frt wheel hops if I make hard left turns)
Old Dec 19, 2008 | 01:13 AM
  #123
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
there is a tool to measure what order the vibration is. It is called an eva or eva 2 or there might even be newer versions. I took a class on vibrations when I worked for a large car manufacturer and this tool is used with a computer program and arranges vibrations of the vehicle in an order. It is a very efficient vibration finding tool and might be your only alternative to find someone in your area that knows how to use it. It uses a magnetic base that can be attached and reads out numbers. These numbers are used by the computer program to isolate if it is an engine vibration, driveline vibration, based on the resonance and "order" how it vibrates. It will find bad tires, anything that you could possibly think of. I used it with success to find a body bushing that was defective under the left front of a chevy tahoe one time, and did multiple tests with weights on a driveline with an instructor to balance a driveline while installed in a vehicle!!! All vibrations in a vehicle fall into a category-order and will save you loads of cash when used properly. Hope this helps.
Old Jun 4, 2009 | 02:23 PM
  #124
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
I was getting all set to do this, but I just thought of something... if u shut the engine off, that stops the outside of the torque converter from rotating (becuz it's bolted to the flywheel). When I shut the engine off and shift into neutral while cruising down the freeway, the vibration continues. So unbolting the converter from the flywheel and rotating it 120 degrees won't help me... right?
Old Jun 4, 2009 | 02:33 PM
  #125
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Axle/Gears: 10 bolt 3.73's
That would be correct. If your shut the engine off then the torque converter is not spinning.
Old Jun 30, 2009 | 02:44 PM
  #126
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Well the outside of the torque converter isn't spinning, but what about the fan inside?
I got new tires a couple weeks ago and finally got a chance to take my car out for a long ride on the freeway. The vibration is definitely much better, presumably becuz the old tires were out-of-round/flat-spotted/dried out/old. W/ that part of the vibration gone, it's ezr to feel the underlying vibration that I can't figure out.
Anyway, I shut the car down and shifted into neutral as a I was getting off the freeway, but the vibration continued and didn't seem to be affected at all. So I can rule out the outside of the torque converter at least... of course, if it was the outside of the torque converter, it would be RPM related, not speed related. And the problem is not RPM related.
And I don't think the fan inside the TC is the problem either... if the engine is off, the outside of the TC is stationary. And if the trans is in neutral, there isn't much force from the trans to turn the fan. So when the outside stops, the viscosity of the oil inside the TC would put a lot of drag on the fan and, at the very least, slow it down drastically. But the vibration was unaffected.
That, and the fact that the vibration is not RPM related, tells me that it's not the TC.
Old Jul 1, 2009 | 08:13 AM
  #127
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I went through this vibration issue for a few years until I finally got it solved. My car is so much more fun to drive now that I know it's not going to vibrate itself apart. Here's a seriously long thread with all the symptoms and troubleshooting I did until I finally figured it out:
https://www.thirdgen.org/forums/tran...-has-me-4.html
Old Jul 2, 2009 | 12:27 PM
  #128
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
So... u went to an aluminum driveshaft? I already have an aluminum DS from a 4th gen and it didn't make any difference.
Old Jul 3, 2009 | 12:16 PM
  #129
RBob's Avatar
Car: check
Engine: check
Transmission: check
This was recently posted on the Chassis & Suspension board:
https://www.thirdgen.org/forums/susp...ue-solved.html
Broken bolts for the torque arm to the rear differential mounting.
RBob.
Old Jul 6, 2009 | 12:45 PM
  #130
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
RBob.
I installed a complete rear axle assembly including the torque arms and it didn't make any difference.
Old Aug 18, 2011 | 12:45 PM
  #131
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
I was kinda watching the "PowerBlock" on Spike this past weekend... I had it on in the background and wasn't paying close attention, but I think it was "HorsePower TV". I think they had a '90s-era Thunderbird and they said something about the unibody sagging over time. They showed a preview that involved jacking the car up and welding in some plates to straighten and stiffen it. Any1 know what I'm talking about? Could these be a potential explanation for the vibration problems many of us have been experiencing?
Old Nov 27, 2012 | 03:18 PM
  #132
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
frame might be bent?
Old Nov 28, 2012 | 09:35 AM
  #133
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Thought about that... but the car has never been in an accident, so I don't know how the frame could have been bent.
Old Nov 28, 2012 | 09:46 AM
  #134
Car: 1987 IROC-Z
off the top of my head. bad U-joints, rear or front rims need balanced, bad shocks, the tires themselves are bad (tough to tell on this, you need to take them in and have them dismounted) hell, a bad tie rod end might do it too. I'm not trying to call you a liar, but if you aren't the original owner..you never know if its been wrecked and fixed before. my car was stolen and totaled..once I'm done with it, nobody will ever be able to tell it happened.
Old May 24, 2013 | 09:51 PM
  #135
IROZINCO's Avatar
Well, you can add mine to the list 87 iroc - pretty much EVERYTHING rebuilt
Vibration ongoing for 3 years now
tires - replaced with new - same
wheels - balanced 3 times
brakes - new hardware all 4 corners
engine - 350TPI - completely new engine
tranny, 700-r4 - rebuilt
3 driveshafts - u-joints, yokes, balanced, the works
totally different 9 bolt rear (89 1le rear end)
tranny mount is stock rubber
no urethane anywhere
vibrates at 55+ shakes dash, steering wheel, shifter, seats, body, etc
has SFC's.
If you are going along at say 60, and you go downhill, and you put tranny in neutral, vibration still occurs, doesn't change.
suspension has been checked 3 times
We have NOT done the pinion thing yet, apparently you can't shim these, you need an adjustable arm.
I've thrown at least $2k in this thing just trying to fix the vibration. If we do the pinion and it DOESNT fix it, i'm out of ideas, options and money! Anything i missed, someone please let me know.
Old May 25, 2013 | 08:57 AM
  #136
Dee555's Avatar
Car: 89 Iroc - 84 Trans Am -84 Corvette
Engine: 350 TunedPort
Transmission: 700R/T-5 World Class
Axle/Gears: Posi/Ausi/Disc/3.08
does the car have brake drums ,,, you may have lost a weight off one of the drums...
Old May 25, 2013 | 04:35 PM
  #137
IROZINCO's Avatar
nope - 4 wheel disc all around. ls1 up front and 1le in back. also changed BOTH axels in rear and wheel bearings on all 4 corners (both inner and outer races in front)
Old May 25, 2013 | 05:27 PM
  #138
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
I had a nasty vibration too. Changed tires/ rims. Motor, trans, front struts, front spindles and all mounts in drive line. I changed out my rear lower control arms and pan hard rod and it finally went away. I had planned on those parts so I was a little stoked by the side effect. I had a bent pan hard rod. Hope my experience helps someone cause it was by far the cheapest thing I've done. Founder performance; I thank u
Old May 26, 2013 | 05:44 PM
  #139
IROZINCO's Avatar
what about the panhard bar was making it vibrate? and what specific tests did Founder performance run to find this?
Old Jul 20, 2013 | 04:05 PM
  #140
squeeezer's Avatar
Car: 5 cars
Im adding myself to the list
Had 0 vibrations untill i swapped in a used th400, and converter, new x member, new trans mount, and new chromolly drive shaft
May the fun begin
Old Jul 20, 2013 | 05:38 PM
  #141
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
For those of you getting vibrations, here's what you should check first. See if your wheels are bent, make sure your tires are balanced, check your alignment, check for any bent or broken suspension parts, see if your axle is bent, see if your driveshaft is bent, check your u-joints, check your pinion for play, check your differential and axles for play, look for broken C-clips, check your wheel bearings.
Old Jul 20, 2013 | 08:27 PM
  #142
Car: 91 formula ws6
Transmission: 4l60E
i found my bar to have a bend in it that made more pressure on the left side. i changed the parts cause i wanted to. i had an awful vibration just like the rest. it would start at 70 then get worse til 105. unbearable by that point. i was just happy as a pig in **** to get rid of that damn vibration. noticed it on my way home from my job that day.
Old Jul 20, 2013 | 11:04 PM
  #143
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
For those with the rpm related vibration, has anyone thought of the tailshaft mounted exhaust hanger? I have a vibration that comes and goes every few hundred rpm and its the long stretch of exhaust that is unsupported since I don't have the center hanger.
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
