t56 l98 swap issue's
Old Dec 5, 2006 | 07:03 PM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
ok i put a t56 trans outta a 97 trans am, in my 91 gta, my issue now is it wont start the starter wont even engage, 100 per. sure its electrical or vats or somethign please shed some light on the situation and give em a hand thank u, ken
sry i fi cant spell
Old Dec 5, 2006 | 07:19 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You probably didn't hook up the clutch switch(if it was a T5 car), or you left a circuit in the neutral safety switch open from the original shifter(if it was an automatic). If it was an Automatic, you need to connect the two large wires in the harness that went to the shifter. I believe they are yellow and purple, but I am not sure.
Old Dec 9, 2006 | 12:18 PM
1BadaGTA's Avatar
thanks for the help but it was a blown fuse and a wire on the starter was wrong. But i bypassed the safety switch and now my car really hauls A$$. But I have the stock 3.23 gears in the rear should I change to 3.73's or 4.10's ? I still want some topend.
Old Dec 9, 2006 | 12:52 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I put 4.10s in mine. It isn't bad at all. Right now my rearend is busted, so I am running a 3.23 rear and I hate it. My car ran about 2000RPMs at 80mph with the 4.10s.
Old Dec 9, 2006 | 01:27 PM
Pat Hall's Avatar
Yeah, running a T56 trans, you'd definitely be happier with more gear, like 3.73's or 4.10's. With the insane overdrive ratio you have in sixth gear, it's probably completely useless with 3.23's!
Old Dec 9, 2006 | 01:39 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
If your sticking with TPI and don't plan to rev past 5k then you might want the 3.73. At the track I found that my 4.10 gears were to much and I had to shift into 5th or just rev the car to 6k to cross the line.
Old Dec 9, 2006 | 04:25 PM
1BadaGTA's Avatar
Well I'm have to keep the car on the street so I guess 3.73's it is thanks for the info guys.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
