t56 swap slave cylinder issues
Old Dec 11, 2006 | 04:54 PM
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
Just finsihed my t56 swap in my 89 GTA, but I have no clutch pedal. I am using an aftermarket t56 with spohn bellhousing adapter. I am also using my original 3rd gen slave cylinder.
When i first removed the slave cylinder I did not pump the pedal i just let it hang loose. When I re installed I had no clutch pedal at all. After bleeding I still had no clutch pedal. SO I guess what I'm getting at is do you think I broke my slave cylinder and need to replace it or do I have to use a special order slave cylinder?
Old Dec 16, 2006 | 07:40 PM
quick ones's Avatar
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
Im doing the same swap what clutch and trowout bearing did you use?
Old Dec 16, 2006 | 09:03 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Is there fluid all over the ground? Unless you pumped it when it was hanging there I dought you blew out the slave.
Old Dec 18, 2006 | 12:25 AM
Axle/Gears: 3:73
I got it to work, it was just some air in the system all is working fine now. I'm using a centerforce Dual Friction clutch and Centerforce bearing. The clutch pedal feels great, all seems to be working well now. Thanks.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
