NEED HELP!
Old Dec 18, 2006 | 07:30 PM
Donald1992's Avatar
Car: 1992 Ttop Camaro
Engine: 3.1L v6
NEED HELP!
ok i just bought a Camaro 1990 305 tbi auto matic ttops i bough this car for 200 bucks and it dont start dont crank or try to start here is whats happening the batterie is changed you put the key in your little dinger sound works ok than when u turn the key over everything dies the dinger nose n everything the headlights dont work nothing does but the batterie is charged i bought the car like this idk if i should get a new wireing harness or i should do a motor swap wouldent the head lights work if the batterie had a charge would really apperaite some info thanks alot
Old Dec 18, 2006 | 08:59 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Check all the grounds body to motor battery to motor ect.You should get some thing to work .
Old Dec 18, 2006 | 09:01 PM
Donald1992's Avatar
Engine: 3.1L v6
the one that comes out of the negative to the inside of the fender?
Old Dec 18, 2006 | 09:17 PM
TexasLT1's Avatar
Car: '92 RS
thats one place to start. then check the ground straps that go from the engine block to the frame. then check the negative battery cable. check any black wire that is bolted to the frame somewhere.
Old Dec 19, 2006 | 06:15 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Start
I would check all the fuses 1 by 1, then have a look at the fusible links
located right on the starter wires and put a meter down there or a 12V test
light turn on the key see if you got any juice down there to the starter..
also do a no start( search) here on this site...
