tv cable
Old Dec 20, 2006 | 12:47 PM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
tv cable
ever since i put in a carbed motor i have not been able to get my tranny to shift right.i have a speed demon carb and the guys at lokar told me which cables and brackets to buy but i still cant get it right.i just put in a raptor junior tranny and i am afraid to burn it up.i had someone inside step on the gas i checked the wide open trottle then loosened the set screw,pulled the cable as hard as possible then tightend it up.it is shifting to soon and forth wants to go in and out.
Old Dec 20, 2006 | 01:09 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
the TV cable on our cars is not actually tight.... the self adjusters are nice way to go. there are two different types. you have the stock like one with the D button. and then another one that has a C-Clip that you remove, and then put in... more than likely you either have a wrong cable, a missing bracket.. or the cable is not adjusted right.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
