wont shift into 4th when flooring it
Old Dec 21, 2006 | 10:22 AM
irocz1228's Avatar
Car: 1990 IROCZ
Engine: 5.0
Axle/Gears: Richmond 3.73 and Aurburn diff
I have heard that the 700r4 transmissions wont shift into fourth at full throttle . why is that? is there anyway to fix it?
Old Dec 21, 2006 | 12:34 PM
Shagwell's Avatar
Car: projects.......
There's a fix to it, but only if you don't really like your trans. 4th is overdrive, it was never meant to handle WOT. OD eats horsepower, 1:1(3rd) doesn't.
There's a 4th gear upshift sleeve available from a few manufacturer's, but it's usually not reccomended for engines over 250hp, because it's hard on the trans.
Old Dec 21, 2006 | 01:29 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
slow down.
Old Dec 21, 2006 | 01:59 PM
irocz1228's Avatar
Car: 1990 IROCZ
Engine: 5.0
Originally Posted by MrDude_1
slow down.
Whats the point in driving a muscle car then?
Old Dec 21, 2006 | 02:01 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
the above mentioned sleeve still does not allow for Full throttle 4th. it takes it from a 70% throttle shift and moves it to an 80% or 85% throttle downshift.. either way, you are driving alot faster than you need to be..
Old Dec 21, 2006 | 02:22 PM
irocz1228's Avatar
Car: 1990 IROCZ
Engine: 5.0
what if i was on the track???? is that still to fast daddy?
Old Dec 21, 2006 | 02:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
getting up to a very high speed very quickly is what driving a muscle car is about.
seeing how fast you can top out a car, is what being a pansy wannabe road racer is about. lol.
i wouldnt worry about it, your car doesnt make enough power to pull 4th at that speed anyway... thats what? 135ish at 5700ish?
even if you did make it shift to 4th... if you had the power to keep pulling, you would just burn up the transmission.
without an additional trans cooler, i wouldnt reccomend any prolonged highspeed hijinks with the 700R4 anyway... it really doesnt like it.
well, its not the quartermile, thats for sure.
im going to assume you mean road course.... i think you'll be better off raising the rev limiter (with better engine mods... aka a new motor) then trying to make that trans live under thoes conditions.
Old Dec 21, 2006 | 03:55 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Shyt mine doesnt even shift into 2nd, 3rd, or 4th without letting off the gas.
OH YEAH....ITS A BUSTED TRANS. I am going to buy a new 700r4 and have the internals removed and replaced....anyone know a place that makes 700r4 internals that are badass.....?
Old Dec 22, 2006 | 10:21 AM
If it's at the track. then fine. but you will never be able to pull even if it did shift into 4th.. your times would suffer.
Old Dec 22, 2006 | 02:35 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
you dont want to shift into 4th in the 1/4 mile. Even when I swapped to a 3.73, Im still in 3rd gear at the end of my run.
Old Dec 22, 2006 | 07:23 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
mine shifted to 4th at WOT just fine. with gears, it pulled pretty decent till 4.5K.
here is a short clip,
http://www.transamws6.com/video/130mph.wmv
Old Dec 23, 2006 | 01:45 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
NICE!!! I rather enjoyed that. Gets up there pretty quick I would say. Now here is my question. How do you build up that top end?
Old Dec 24, 2006 | 01:06 AM
Zepher's Avatar
That was a stock 305TPI/Auto with 3.73 gears. Only mods at the time were K&N air filter and the gears.
Old Dec 24, 2006 | 01:46 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Nice music
That thing pulled pretty good for a lil 305!
I woulda sent rods out the hood and fenders if i ever got up to 130mph, thats about 7000rpm for me...
Old Jan 28, 2018 | 04:15 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
Re: wont shift into 4th when flooring it
so what did you do to make it shift.... i thought i read somewhere that the vetts shift 3-4.
Lanz06
Sep 14, 2015 07:16 PM
machinist21
Sep 5, 2015 03:03 PM
rudolphschenker
Sep 4, 2015 02:41 AM
mrdevontay
Sep 2, 2015 08:04 PM
