pinion depth for 9-bolt?
Old Dec 27, 2006 | 02:57 PM
TexasLT1's Avatar
Car: '92 RS
Anyone know what the pinion depth for a 9-bolt is? or where to find it?
*edit* its a 3.70 gear ratio set, US Gear. numbers not etched on either gear.
Old Dec 28, 2006 | 03:39 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
use the shim under the bearing that is still on your old pinion.. its the right one 99.5% of the time.. I have only changed 3-5 out of the 3-400 rears I have ever put gears in..
Old Dec 28, 2006 | 03:46 PM
TexasLT1's Avatar
Car: '92 RS
well, I'm completely changing the internal parts. different carrier, obviously different gears. if you mean the shim that was in the rear originally, it got destroyed removing the pinion head bearing race. but, the new pinion has the shim on it beneath the bearing. I'll just leave it on then.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
