Kickdown cable mounting on my new edelbrok carb. Help
Old Dec 28, 2006 | 10:38 AM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So i need to know what bracket or if its a braket to buy for the kickdown cable or tv cable for the tranny that hooks into the carb. the cable is fried too and i need a new one is it hard to replace? Thanks.
Old Dec 28, 2006 | 11:05 PM
TABANDIT's Avatar
Car: 1987 Transam
Engine: 1991 350 Bored .030 over
Transmission: TH350 w/stage 2 shift kit
Ok, if I understand you correctly you need the thing that attatches the kickdown (tv) cable to the carb.. It it just a little stud that screws into the opposite side of where you attached to throttle cable. Part #350-8018 on http://www.jegs.com/webapp/wcs/store...24131_-1_10313 . As for replacing the cable itself, I don't think that its too hard, although I have only done it when the motor and tranny are out of the car, but I can't see it being that big of a deal if you can get under your car.
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
willyjoejr
Sep 3, 2015 09:26 AM
