Decode rearend 5 PM C 1 8 1 2
Old Dec 30, 2006 | 12:42 AM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
I pulled this rearend out of the 83 T/A I am parting out. It has rear disk brakes and a 5-speed. I am hoping this is a 3.73 posi.
I can spin the yoke and both wheels want to spin the same direction but all of the sudden the passenger side doesn't spin. If you grab a hold of the drivers side the passenger side spins then.
Is this the sign of a worn out positraction????
I can spin the yoke almost 2 full turns before the axle turns 1 full turn. I can't tell what axle ratio it has by that so I guess I might be pulling the cover to see what it has in it.
Old Dec 30, 2006 | 05:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That's the best way to determine what you have. Here's how to determine what ratio the rear is (numbers are stamped on the ring and pinion):
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Old Dec 30, 2006 | 12:49 PM
Those "codes", like all other of those, clearly mean that if you want to know what's inside, you need to have to take off the cover and look.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Elephantismo
Feb 13, 2019 12:51 AM
F-body-fan
Sep 24, 2015 08:29 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
