gear ratio
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
gear ratio
i have a 1986 trans am and the rear end went out . i purchased one from a 89 now my speed ometer is of 30 mph advanced and it drinking way more gas. do anyone know the original gear set up. so i can replace with the righ ring and pinion.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Unless your car has the G92 RPO code, a 1986 TransAm with a 305 and 700R4 will originally have 2.73 gears (highway gears)
The diff from an 89 could have 3.08 or 3.42 which will reduce your fuel mileage but will increase the performance of the car. That is providing those gears were original and the previous owner didn't install something else.
Pull the rear cover and count the teeth. On the ring gear should also be numbers saying how many teeth are on the ring and pinion.
Car: 87 IROC L98
If you're willing to live with the fuel mileage because of the deeper gears, you can change the speedo drive gearing in the tranny to fix the speedo calibration.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
once you figure out what gears you do have, bowtieoverdrives has a speedo gear calculator to tell you which gears you'll need to purchase to correct your speedo.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
