aftermaket tremec tko tans
Old Dec 30, 2006 | 04:32 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
do you need to change the drive shaft for the tko trans?
Old Dec 31, 2006 | 01:03 PM
Pat Hall's Avatar
You have to use the Ford C6 style 31 spline slip yoke to fit the tremec trans and the proper adapter u-joint to mate it up to your factory driveshaft. The u-joint is 1330 size on one cross and 1310 on the other cross. As far as length is concerned, everything I've read about the swap says the stock length works fine. When you buy a brand new TKO, most places include the slip yoke with the trans. Mike Forte sells the correct adapter u-joint too.
Old Dec 31, 2006 | 02:51 PM
jayk2k3's Avatar
Car: 85 camaro z28
wat about a richmond trans?
Old Jan 1, 2007 | 04:19 AM
Pat Hall's Avatar
Personally, I'd go with a TKO anyday versus a Richmond 5 speed. The TKO is actually an overdrive transmission with 5th gear being either .68(TKO 500) or .64(TKO 600). The Richmond 5 speed is no different than an old school 4 speed trans since 5th gear is 1:1. Plus you'd need a longer driveshaft since the Richmond is the same length as a Muncie or TH350. The GM spec TKO also comes with a 26 spline input shaft so you can use the same clutch/bellhousing setup as the factory V8 T5 thirdgens.
Old Jan 1, 2007 | 01:01 PM
jayk2k3's Avatar
Car: 85 camaro z28
thanks 4 the info. the tko seems the better and easiler way to go.
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
topteam54
Oct 6, 2015 12:21 AM
89bird2.8
Sep 25, 2015 09:21 AM
Navy8125
Sep 23, 2015 01:11 PM
