t5 crossmember problems
Car: 83 z28 camaro
Engine: 5.7L 350 4bbl
Transmission: T5 5-speed
i am dropping a t5 in my 83 camaro.its already in but the crossmember isnt lining up properly to bolt it up.it seems crooked or something.the mount is good, i dont know.can anybody help.
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
On the 82-84 cars the original crossmember is different. I had to drill and tap a new hole for one of the bolts. 3 out of the 4 lined up though.
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
Crossmember
On a 83 isn't the torque arm mount different??? I have a crossmember for that car if your interested. I just pulled a T-5 with manual clutch and the whole 9 yards out of a 83 T/A.
Car: 83 z28 camaro
well i figured it out,its actually a world class t5,i had to replace the bellhousing and its the wrong one.so looks like im on the market for a whole new tranny
The world class T5 is no different than the non-wc ones as far as the bellhousing is concerned. There were only two different bellhousings. The early one for mechanical clutch linkage (82-83), and the later one for hydraulic clutch linkage (84-92). Either one will work with both the WC and Non-WC units, as long as it's the V8 bellhousing and not the V6 one. Both of the correct bellhousings mount the tranny tilted towards the driver's side of the car instead of straight up. If you have an old style bellhousing that mounts the trans straight up instead of tilted, that's your problem. Send a PM to Transformula87. He had one for sale in the classifieds here for $45 shipped, which is dirt cheap for a T5 bellhousing. They go for twice that easily on ebay. It was last posted on 12/13/06 in the engine/drivetrain parts for sale section.
GeneralIesrussi
Sep 3, 2015 03:23 AM
