transmission that will handle power
Old Jan 2, 2007 | 01:55 PM
sLoW'n'StEaDy's Avatar
wondering what would be a good choice for an auto trans that will be farily easy to put in my 88TA. Has to be handle quite a bit of power. I KNOW my T-5 wont last more than a minute or two once i get the new engien put in, and a friend of mine keeps saying he wants my engine/tranny setup i currently have for his camaro. I know NOTHING about auto trans AT ALL!!! i have switch a few cars form auto to manual, but never from manual to auto. only trans ive heard much about at all is a TH400, any good?
in case you've seen any of my other posts, my build has taken a bit of a turn, i guess my girlfriend really like my TA so instead of making it a tin can, i will be pretty much doing the opposite, redoing the entire interior, fiberglass door panels, black everything. yadda yadda
Old Jan 2, 2007 | 11:38 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
how much power? what's the purpose of this car? motor specs? cam specs?
need overdrive for highway use?
Old Jan 2, 2007 | 11:54 PM
TexasLT1's Avatar
Car: '92 RS
I ran a T-5 for 3 years behind a 12 second LT4 with a Centerforce Dual Friction clutch doing 3k+ rpm clutch dumps. so before you go on about KNOWING it won't last, give us some specs on the engine you plan to install and that will help give you a reccommendation. I HIGHLY doubt you'll need a TH400.
Old Jan 3, 2007 | 12:16 AM
350 bored .030 over, forged 383 crank, forged rods, forged pistons, 224/224 114LSA cam, Weiand Team G intake, Demon 850 blow thru carb, double hump or vortec heads (havent decided yet) twin T70 turbos, twin A/W intercoolers, MSD 6BTM ignition
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
You could run a th350 for 500hp + if you build it right, and you can get them built pretty dam cheap.
Thiers a guy around here who will build it to handle 500hp, for $400
Old Jan 3, 2007 | 12:19 AM
gonna need it to handle a little more than that, the engine naturaly aspirated would be close to that
Old Jan 3, 2007 | 12:33 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well first of all, i would opt for the vortecs(ported of course) and a built th400 for your application, and by the way, select a blower cam for your application also, they will have on to fit your requirements.
Old Jan 3, 2007 | 12:58 AM
EvilCartman's Avatar
Car: '82 Z28
Mike's Transmission. The TH400 I'm running came from a car that had a blown BBC putting out around 1000 hp. It was built by these guys.
Old Jan 3, 2007 | 01:08 AM
Honestly i would like to have a manual transmission i just dont know what type of trans would be good. How much can a stock T56 handle?
Old Jan 3, 2007 | 01:29 AM
xpndbl3's Avatar
Car: 1984 Z28
turbomustangs.com
read it and read it and read it
you know a blow thru 750 type carb is good for 1100 hp right? Furthermore, check that site out and realize that cam is a poor choice for a blower, get a split duration for your heads. a twin turbo 383 is a nice choice, but it seems like you need to research it a bit more before proceeding, if you have the cash for twin turbo and a T56 then run aluminum heads and good luck.
Old Jan 3, 2007 | 08:35 AM
TexasLT1's Avatar
Car: '92 RS
450ish hp. do a G-Force upgrade and its "rated" to 900hp and 900 ft-lbs
and I take back what I said in my first post, TH400 with a manual valve body would get you your "manual" transmission if you wanted to go that route, or check into the G-Force kit. its not cheap, but worth it if you want to keep a manual trans.
Old Jan 3, 2007 | 01:45 PM
OK, also i htought i remembered hearing that there are a couple different size TH400, like a short one and a longer one from a full size car. which would be used?
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
