Ultimate Hyd. Clutch Linkage Bargain Style!
Old Jan 3, 2007 | 03:03 AM
Pat Hall's Avatar
Anyone looking to improve their thirdgen T5 hydrualic clutch linkage might be interested in seeing this. The only better setup you could do would be to go with McLeod's ultra-expensive adjustable aluminum master cylinder, braided line, and aluminum slave. The only thing that cost me any decent amount with the setup I threw together was purchasing an aluminum thirdgen replacement slave instead of the cheap plastic one. The master cylinder and braided steel line came off a 93-97 style 6 cylinder f-body, which I got dirt cheap at the wrecking yard. I couldn't get the braided steel 4th gen line to work with a thirdgen plastic slave, but it fit perfect with the aluminum one! Just thought I'd pass this along to anyone else looking to upgrade their thirdgen hydraulic linkage since every part of it is made of cheap plastic. The aluminum slaves are getting harder to find, but I think board member Nelapse can still get them. Btw, I mocked this assembly up on the workbench, filled it with fluid, and bench bled it to make sure there were no leaks anywhere, and it works great!
Attached Thumbnails Ultimate Hyd. Clutch Linkage Bargain Style!-000_1147.jpg   Ultimate Hyd. Clutch Linkage Bargain Style!-000_1150.jpg   Ultimate Hyd. Clutch Linkage Bargain Style!-000_1151.jpg
Old Jan 3, 2007 | 03:43 AM
Pat Hall's Avatar
Here's a few more pics. Don't mind the ugly inspection cover, still gotta paint that! That's the quality of parts you get when you buy from Camaro Heaven in NH when they sell things on Ebay! Lol.
Attached Thumbnails Ultimate Hyd. Clutch Linkage Bargain Style!-000_1153.jpg   Ultimate Hyd. Clutch Linkage Bargain Style!-000_1154.jpg
Old Jan 3, 2007 | 06:16 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
If you can find that set up you are in good shape. That is a very reliable set up. The slave line looks very long but is quite doable. You only need 13" of line and even then you have quite a bit of play.
The setup I sell is
Aluminum Slave, ss braided removable line, with mcleod fittings.
This goes for $220
plus I do not sell aluminum master cylinders.
If you can find them, then you have yourself a hydraulic system you will never have to worry about again.
Old Jan 11, 2007 | 03:44 PM
Pat Hall's Avatar
Figured I'd bump this up again....
Old Dec 19, 2007 | 01:52 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Ultimate Hyd. Clutch Linkage Bargain Style!
Anyone thought about using this master? http://store.summitracing.com/partde...t=CNS-CM116360
Old Dec 19, 2007 | 06:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
ive got the same setup as pat, and the slave from nelapse, great stuff, its nice knowing that things will last.
Its funny, i never knew there was a "shield" for the slave, i guess ill have to get one.
Old Dec 20, 2007 | 12:34 AM
Pat Hall's Avatar
I scored my slave shield off of a V6, T5 equipped thirdgen in the junkyard. It seems like there's a never ending supply of V6 5 speed cars in the yards around here. Although the shield isn't entirely necessary, it probably helps keep the slave cooler when running headers.
Old Dec 20, 2007 | 08:18 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I dont think that part has anything to do with cooling, especially for the plastic slaves. I think it is just a stone guard
Old Dec 20, 2007 | 11:12 AM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
The setup I sell is
This goes for $220
How much for just the line and fittings? I already have an aluminum slave.
It however is called a heat shield by GM.
Old Dec 20, 2007 | 03:14 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Just says Shield in the parts book
Old Dec 20, 2007 | 03:27 PM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
You can get aluminum slave cylinders from Summit. Coniseal makes them, part #CNS-SC126869.
Old Mar 14, 2009 | 08:34 AM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Old thread but this might be useful to someone.
I was looking at options for my clutch hydraulic system and wanted to have one of these aluminum slave cylinders on hand. Summit still sells them with essentially the same part number (SC126869) however, estimated time to ship is often listed at about three weeks. I discovered that Wagner sells the same part with the same part number and I could order it through NAPA or any other parts place that deals with Wagner ($64.95 CAD).
OK, So what? Well as a Canadian at the current horrible exchange rate buying it locally saved me $16.00. Also saved another $30.00 on shipping and $20.00 on the customs/brokering etc. You get the idea.
Another bonus was that rather than waiting a month for it I had three hours later!
Like I said, not exactly a rock-your-world post but it might be useful to someone.
Jon
Magman
Sep 14, 2015 01:30 AM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
