ls1 t56 part numbers
Old Jan 6, 2007 | 12:12 AM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
(t5 bell -> lsx t56) I know the part numbers for the adapter plate and pilot but were can i get the x member and a tq arm and drive shaft that will work? Part numbers or manufacture names will be greatly helpful.
Thanks!
8617 Pilot Bushing
8-207 Adapter plate
Old Jan 7, 2007 | 12:13 AM
Mdenz3's Avatar
Car: 91 RS
Axle/Gears: 3.42 LSD
http://www.hawksthirdgenparts.com/in...ROD&ProdID=883
thats the crossmember and torque arm you'd need, as for the drive shaft i belive you can just have your shortened to the correct legnth.
Old Jan 7, 2007 | 12:36 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
That this is sweet. I looked at it but wasnt sure if it would work or if i still needed a xmember to go with it. But upon closer examination i see that its everything in one. Im definatly buying that its well worth the price.
Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
