What does the 2 and the 1 mean, on my selector..
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
You know after D or [D], I can't remember which comes first or w/e...
My parent's cavy has them too, and my dad says they are for snow driving...
So what are they used for exactly?
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Throw it into 1 when you want to pass another car on the highway.
DO NOT THROW IT IN A LOWER GEAR ON THE HIGHWAY!
Sarcastic advise is wrong. Advise that could injure others will not be tolerated.
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
who told you first for passing on the highway. if i go over 30mph in fist its ineffective. that why your auto tranny switches gears between 20 and 30. its a quick gear and if you need to stop quickly from high speed and dont really mind getting a new tranny sooner than you should you can drop down to 2 or 1 from overdrive. other than that its point less to use then on any auto, unless you want to govern your speed because there a cop behind you or something stupid. it doesnt make sense to slap shift from 1 to 2 then overdrive like few ppl do. your car is disigned to do that for you and jumping through drive to overdrive is only gonna make your car feel weird and drop your speed while the tranny try to figure out where it should be.
pretty much dont worry about using them.
its only my experience that you cant go faster than 30 in first and unless your joking id like to see someone try that 1st gear highway pass in any car other than mine cuz i dont believe it would ever work.
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
whats the difference between drive and overdrive. sorry dumb question just curious what applications they should be properly used in
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i think if you drop it into 1 to pass at highway speeds, the car may go boom...
Car: 82 Trans AM
Transmission: th350 turbo
If you select 1 the car will stay in first.
If you select 2 the car will still start out in first and then only up shift to second.
If you select 3 or D it will goes through first, second, third.
If you select the boxed D (boxed D signifies OD) it will go through the whole range 1, 2, 3 and then into overdrive. Overdrive is when the engine is at a
1:1 ratio with the tranny for maximum fuel economy, but makes the engine have a sluggish response.
Car: 82 Trans AM
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Overdrive is exactly what the word says... the driveshaft is spinning faster than the engine is. An overdrive gear (4th) is a ratio smaller than 1:1. IICR, a 700R4 has a .73:1 ratio for its OD gear.
Axle/Gears: no idea
so for normal driving around town what should i be in drive? and overdrive for highway? or does it matter?
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I usually leave it in overdrive unless I feel like some spirited driving...
Last edited by thirdgen88; Jan 19, 2007 at 11:25 PM. Reason: Automerged Doublepost
Car: 88 Camaro SC
Engine: 305 TBI
Axle/Gears: Posi
Car: 1989 Pontiac Trans Am GTA
Engine: L98 TPI 5.7L
Transmission: Stock ... For now
Axle/Gears: Borg-Warner 9-Bolt
On my 700R4 I use 2 & 1 for engine braking, and racing cause I can strech the gears a little better than the tranny does and I get better ETs. in D ot [D] the Tranny shifts too low for my driving style
Car: 91 Z28
Axle/Gears: Stock
Pretend your automatic is a manual for a second...
1 = 1
2 = 2
3 = d
4 = OD
If you have a certain gear selected, it will shift up to, but not over, that gear.
For highway driving ALWAYS drive in overdrive...unless you want to be running very high RPMs...and high tranny temps and such. Oh, and it will drink gas too
1 = 1
2 = 2
3 = d
4 = OD
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Gee go easy on the kid we were all 16 once too. Although we probably knew that 1 and 2 were gears. Anyway the ? has been answered.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Around town, its always in drive (3rd). 50 mph or higher (Highway) is Over Drive (4th), shifting back to drive (3rd) on the off ramp. Thats it.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
PM's sent to those who are out of line. More pm's to follow.
Replies to any topic should be helpful.
Nothing nice to say............say nothing.
